F1 Prochargers...
There is also a few mustangs running F1 heads on thier little old 4.6 engines!!
There is even an F1C (larger than the F1 and F1A) kit for the vettes, and they have more room to work with. It's a much tighter fit with the Fbods.
wish there could be more out there on the streets!
i followed your thread where ya changed back to the D1 cause ya couldnt slow this F1 down enough...lol...im gonna be running it on a fully built 402 but i only wanted to run 15-16psi or so...you think this will be doable???
im afraid to run out of steam with a D1 and thats the only reason i wanna do an F1.
As far as F1's on LT1's you just have to cut a portion of the block and grind down the ABS bracket and 2 studs that's it. It'll fit as I have an F1.
An F1 will work fine on a 402, dont let what I do dictate what you should do. Its a balancing act for me between the HP the blower uses, belt issues and IAT, I just like to play around and get the most I can out of the least - its easy to get the most out of the most. I run a very small overlap cam and am way more concerned with low/midrange power with very limited boost since I dont have the cubic inches to move a heavy car. Most guys use the bigger blower because they run big cams and cant make the power with the smaller head units, a blower can only move so much air no matter what you do. But there is a diminishing (not to mention belt issues) return by turning a big blower faster to make up for usable boost getting blown out the exhaust..
im not doin stuff based on what you do...i understand with differant engine set ups and cam selection will net you differant results...i just follow what you've done and the reasoning behind it and try to learn as much as i can. as far as real world experiance i would trust you over anyone else on the board...not that everyone else isnt as knowledgable...you've done it and i appreciate the info and insight you provide.
thanx!
Rick
thanx!
Rick
I wasnt implying that you were following what I did, I just meant there is more then one way to achieve a goal and I take a somewhat convoluted approach at times because I just like to squeeze everything I can out of what I have and budget constraints - not because its the best way to do something really.
8 rib belt with tensioner .
There are lots in oz changing to gilmer drives, I stumbled on a Ford Performance shop to pickup a catch can, not knowing they were all ford mad and they had the gilmer on everything P1sc, Disc & F1a, all making big mumbo too.
