I'm Baaaaack
Thats how mine is anyhow unless you have a different BS3 then I do, harlan 2 step needed a ground to work..
Right out of the BS3 manual:
2-Step RPM:
When 12 Volts is applied to Main Header Connector pin B2, the ECU will begin rev limiting the engine to the 2-Step RPM setting in the Operating Parameters Configuration input window.
2-Step RPM:
Thats how mine is also. +12V on the BS3 2 step and the same on the Rossler brake. Mine are both wired to the same button.
of all the connections i was making i am not surprised i had one jotted down wrong.
ill look into it, thanks.
i rebuilt the stock alternator from alternatorparts.com or something similar.
unbelieveable!!
Anways, let me know how the s3/4l80e works, got the setup working...
congrates!!
