Problem with missing/bogging above 6 psi
Old Mar 14, 2007 | 02:46 PM
thunder550's Avatar
High on diesel fumes
Default Problem with missing/bogging above 6 psi
I'm having a problem with my motor missing or bogging when I get above about 6 or 7 psi on the turbo. I can run 6-7 psi WOT and it's fine, but part throttle has a few issues, and WOT above about 6 psi has issues. Scanner is not showing any KR, and I'm only running 11* of timing right now, so it should be fine. AFR is right about 11.5, I'm using TR6 plugs gapped to .035, and stock plug wires. I have no idea what's going on......anyone have any ideas? It accelerates well until I hit a certain boost level then feels like it starts to stutter or something. SCR is about 9.5:1 and DCR is about 7.0:1 and I'm running 91 octane, no meth right now. Wastegate is plumbed into the intake manifold behind the throttle body.
Mods are in sig.
Old Mar 14, 2007 | 02:51 PM
JMBLOWNWS6's Avatar
Have you read the plugs after a hit? What is your fuel pressure? You running the maf or are you in SD? Have any logs? Sorry for all the questions. Trying to help you out.
Old Mar 14, 2007 | 03:07 PM
thunder550's Avatar
I do have some logs, I'll see if I can post them when I get home later. I haven't pulled the plugs yet after a hit. Fuel pressure is good, about 65 psi. I am running 2bar OLSD.
Old Mar 14, 2007 | 03:11 PM
JMBLOWNWS6's Avatar
The boost enrichment table multiplier can cause it. Are you using HP or EFI? If you are using HP send me your file. PM me for my email addy. Ill take a look at it for you
thunder550's Avatar
EFI...I think my boost enrichment table is zeroed out though. I'll check it later and post some screenshots since I'm not using HPT.
Old Mar 14, 2007 | 03:16 PM
cablebandit's Avatar
i bet its a/f rich/lean at p/t in boost...dunno about wot issue
Old Mar 14, 2007 | 03:23 PM
thunder550's Avatar
It reads right around 11.5 when it happens. I need to do a recal on the wideband anyway though, it's been awhile since I've done it.
Old Mar 14, 2007 | 03:51 PM
JMBLOWNWS6's Avatar
A good person that can help you out on this site is Chad. Hes a sponsor here. Black02ss GLM is there sponsor name
Old Mar 14, 2007 | 04:19 PM
thunder550's Avatar
I'll check that out, thanks
Old Mar 14, 2007 | 04:46 PM
JMBLOWNWS6's Avatar
No problem Chad helped me alot when it came down to tuning.
