Those using nitrous jets for restrictors come in!
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
I am also interested in a response to this..... How much do they really need and what it to little. I know how to restrict it. I just don't know when I have starved it.
Ultimately, this doesn't require very exact science. You will be surprised how much oil will get through the jet. You need about 15psi. If you are curious about volume, pull your drain line off the pan or pump and run the car for a quick second to see how much drains out. A pencil thick stream is more than enough.
