Underhood Temps. Is there a Fix?
Old Mar 15, 2007 | 01:07 PM
1INSANEGTO's Avatar
Default Underhood Temps. Is there a Fix?
My underhood temps are really hotttttttt...
What kinds of things can I do to solve this?
Coatings -What type
Turbo Blanket- where to get it
Wrap DP- heard that was bad
Other tips.
Or I was thinking a ricer vent where the turbo is
Or just cut and mold a cowl on my hood
Tips ideas etc.
Old Mar 15, 2007 | 01:18 PM
abbaskhan's Avatar
i used coatings wrapped the turbo
Old Mar 15, 2007 | 01:38 PM
Mike 01WS6's Avatar
Use a coating on the hot parts. Wrap the turbo if needed- I heard this decreased bearing life in the turbine....may be true, may not be.
And a vented hood never hurt anyone either. The more airflow in the engine compartment, the lower the temps.
Old Mar 15, 2007 | 01:42 PM
Country Boy's Avatar
Senior Member
I had my stuff coated and a blanket. You could get a heat extractor hood, if they make one.
Old Mar 15, 2007 | 01:49 PM
ibgoatin's Avatar
On my TT GTO I used coatings on all hot parts, turbo blankets, and I used header wrap on my DP's, underhood temps are compariable to stock. I've had zero problems.
Old Mar 15, 2007 | 01:50 PM
Senior Member
Thats right, I had wrapped everything also.
Old Mar 15, 2007 | 01:58 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Coat and blanket the turbos if you want. Does nothing to the units....
Old Mar 15, 2007 | 02:06 PM
sytyjedi's Avatar
Hood louvers directly above the turbo(s).
Old Mar 15, 2007 | 02:29 PM
erikthegoalie's Avatar
and dont forget water wetter and 160stat, and fans turn on at 160. also wrap teh header if u dont want to wrap teh DP. what are ur underhood temps if they are so bad????
Old Mar 15, 2007 | 02:42 PM
NA$TY-TA's Avatar
This is another awsome reason that people cut the front of the bumpers on the TA's..... get the cooler air in there.... I would notice a 20 degree rise in engine temp back when i had my blower in the car and the cover over my front license plate hole....
I agree with the fans on sooner and watter wetter. All of my hot-piping is coated also....
Kyle
Old Mar 15, 2007 | 06:00 PM
black98ws6ta's Avatar
Take the hood off, and everything will be good lol
Old Mar 15, 2007 | 06:15 PM
Juiced's Avatar
speaking of blankets does anyone make one that will fit a thumper?
Old Mar 15, 2007 | 06:37 PM
DMH Fabrication's Avatar
I was wondering the same thing. Maybe PTK?
Old Mar 15, 2007 | 07:01 PM
kidcamaro98's Avatar
i have piping heat wrapped but i also have my Fans to come on High at 180*...so they are always on and i never see more then 190* even on the hottest days
Old Mar 15, 2007 | 11:38 PM
RW99's Avatar
Ditch your AC and throw some really serious fans on front of the radiator. I was marginal in stop and go traffic on warm/hot days, and now it's 180 flat all the time. I realized that I'd never turn the AC on anyway with the car running as hot as it was.
Old Mar 16, 2007 | 03:02 AM
chuntington101's Avatar
coat and wrap (if you can) all hot parts in the engine bay.
get or have made a vented hood (dont forget you have to ge thte hot air out the engine bay to!)
if its effecting engine temps then think about a bigger/better rad.
bigger rad fans (butn thats not going to sort the problem out on make it go away for a little while)
lower temp sat.
bigger water pump
BIG oil cooler mounted out the eengine compartment (maybe laid flat towards the rear with a fan mounted above it???)
apprt form that im not sure!
have you checked everyhting to make sure somethings not causing higher than normal temps????
Chris.
Old Mar 16, 2007 | 08:33 AM
bboyferal's Avatar
T-Stat, water wetter, and a turbo blanket... I've never had some of the problems you guys are mentioning... I've run my A/C in 90+ degrees F and 90% humdity, and I have not gone over 195ish, ever not even in traffic... Only after an hour or so in traffic do my underhood temps affect my alternator... But not since going with a HD LS1 alternator from Afterthoughtsauto. I have nothing vented or wrapped.
I have decided recently to go with an oil cooler... With my old T-70, I would lose oil pressure after rowing through the gears a couple of times... I don't want that happening with a hungrier T-76... Definitely a good idea.
