magna charged F-body
Sorry I haven't stepped in here to answer questions sooner, but as I told Mark in my PM to him, I have been working on getting my new shop open, and haven't been near a phone or computer as much as I should. Since I am pretty much a one man show, I have to do everything, and the internet is usually at the bottom of the list
The Magnuson kits don't require nearly as much cutting as some of the one off installs did. Our kits don't require removing or relocating anything, and they come with everything that you will need. Due to the number of different hoods avaiable for f-bodies, it's hard to say exactly how much (if any) cutting will be required to the hood. I have a 99 Trans Am in the shop now, and we didn't have to cut anything from the hood!
I am trying to shrink some pictures, and I will post them here.
Tha nks,
Ed
What email address are you using? I know you and I corresponded several months ago, but I have not seen anything from you either in email, or a phone message since Nov/Dec.?? DId I miss something?
Ed
I have not had ths car to the dyno yet, but it works extremely well. If my SOP dyno is working properly , I would say it's north of 450RWHP. This is a bone stock A/T car making 7 PSI
As far as I know, TVS blowers are still in development. Once I get my hands on one, I'm sure I can make it fit, but I have no idea when I will be able to get one. When a bigger blower is available from Magnuson, I will try to offer it as an upgrade to this kit.
Hope this helps,
Ed
I wonder how that'd fit with a factory Ram air lower air box. Would love to hear the intake on that through a BGRA kit
only question is what about the new L92 heads? probably means those with those heads will have to wait for and updated manifold from Magnacharger?
I didn't have the factory ram air box, this is an aftermarket hood. I'm sure it could work, the lid has to be cut at a funky angle to mate up to the 90MM TB
Ed
I don't know of a cable operated factory 90MM, but if the lever is on the pass side, then it would be the same. I had to make an extension housing to space it out far enough for the lever to clear the pully at WOT. The bolt pattern is the same, so if someone was able to adapt a drive by wire factory 90MM TB(elec motor on driver side), then you could delete my extension housing and have enough room for a MAF. I wouldn't begin to know how to do that, but I'm sure someone out there can!
Ed
So sounds like you just need to make a small spacer to clear the pulley at WOTThat's pretty much what I did, I just used the FAST 90MM TB, but any LSx 4 bolt 90MM TB should work.
Ed
in my latest reading GM high tech states K-member lowered a few inches?
http://www.gmhightechperformance.com...kit/index.html
when I started this thread the pictured car do'esnt appear to be lowered blower appears higher and cowl is cut much more?
also how well will the car run without a MAF?
Thanks
Thanks
It does not affect handling at all as far as I can tell, The alignment is dead on.
The lms kit is not the one pictured in the first post. You dont have to cut any of the plastic cowling or the hood.
As far as the mafless Ed has got it down pretty good.
I'm also in Atl so if you have any ?s let me know. In case your interested I now own the car in badmonkeys sig.
The only downside to the maggie is what happened to my car.
https://ls1tech.com/forums/forced-induction/973112-extremely-bad-night.html
https://ls1tech.com/forums/showthread.php?t=973112
If you get the blowoff from MC I would not just postup here but all the other simiarl fourm sites MC does,nt want bad advertising.
Hearing stuff like this makes me lose interest in modding extreme (Boost)
I now plan a slitely bigger cam and NA heads.
Thanks
As far as I know, TVS blowers are still in development. Once I get my hands on one, I'm sure I can make it fit, but I have no idea when I will be able to get one. When a bigger blower is available from Magnuson, I will try to offer it as an upgrade to this kit.Hope this helps,
Ed
