stock internals vs. boost
Old Mar 17, 2007 | 06:17 PM
eLTwerker's Avatar
Default stock internals vs. boost
Stock bottom end(not incl. rear end) can safely handle how much boost?
Old Mar 17, 2007 | 06:22 PM
99Z28LS1's Avatar
i dont think its the amount of boost but rather the amount of hp. mine is at 503 with 5.5 psi
Old Mar 17, 2007 | 08:13 PM
67Firebird455's Avatar
Depends on AF ratios you run, as well as compression of course and advance. If you can get the right combo, and less-restrictive heads ("less boost") then you'll be pumpin out decent numbers like ^
Old Mar 17, 2007 | 09:22 PM
eLTwerker's Avatar
You're right. I guess my question should've been: how much hp can stock bottom end handle?
Old Mar 17, 2007 | 10:06 PM
badnuz's Avatar
mine died at 600rwhp and 8#
Old Mar 17, 2007 | 10:57 PM
TERMINAL VELOCITY's Avatar
About 550 RWHP with a good tune.
Old Mar 18, 2007 | 01:35 AM
todd4168's Avatar
mine died at 10lbs and 500 hp
Old Mar 18, 2007 | 01:38 AM
NemesisC5's Avatar
Default 657/574 at the wheels at 9.4psi
Old Mar 18, 2007 | 01:49 AM
99Z28LS1's Avatar
the safer you keep everything in check with the stock bottom end, the longer it'll survive my friend
Old Mar 18, 2007 | 01:58 AM
Zombie's Avatar
Got a friend running 10.20 @ 133 in a 3600lb car, stock internals, but it does have rod bolts. I'd say the stock interals are good for around 700-750 rwhp if you know what you are doing.
I lost my stock motor to rod bolt stretch after 15k miles of 14+ psi and 600+ rwhp.
Old Mar 18, 2007 | 05:04 PM
blacktransam's Avatar
mines made 698/742 but thats on the bottle..
Old Mar 18, 2007 | 06:15 PM
Pewtavert's Avatar
I hear that its all in the tune. Detonation will be a killer so it is wise to take out some insurance in the form of a bottle of Torco with every fuel fillup, an alky kit & a boost-a-pump amongst others. I decided to upgrade to a high perf fuel & oil pump with a dual roller chain also. Will this guarantee my stock bottom end will last....NO......but it is insurance.
