Methanol injection
Old Mar 27, 2007 | 02:06 PM
half-n-half's Avatar
yeah, and you dont have to mount anything anywhere... and this whole time iw as thinking to reuse the tank for methanol and no more windshield cleaning.. haha
thanks for the info
1INSANEGTO's Avatar
Here is what I did to cut cost big time.
I got everything I needed off ebay
A complete kit without controler or res. I have a Eboost2 which has a power output that turn the pump on after a set boost psi. I have mine set at 3psi.
Complete kit setup I paid like $180.00 shipped. Its the same pumps everyone else is using someone just sourced out the meth pumps like all these other companys are doing and built a kit.
Takes 2 bottles to fill my windsheld res. so $8.00 and it should last you a while because your not going to be in boost all the time
Old Mar 27, 2007 | 02:07 PM
ninetres's Avatar
Originally Posted by 1INSANEGTO
Yup. Works great!!!! and keeps cost down also.
$5 for 32 ounces of 65% meth is not a great deal. Just FYI. Pure meth is not that expensive and a 5 gallon drum will last FOREVER.
Old Mar 27, 2007 | 02:10 PM
1INSANEGTO's Avatar
Run pure meth and see how long any pump lasts Just a "FYI"
For some Pure Meth is hard to find and can not be found at times but at the track or at a fuel supply place. O and spray prue meth on your windsheild and see what happens also.
Old Mar 27, 2007 | 02:33 PM
ninetres's Avatar
Not only do I not have wipers, I wash my car enough.....I don't use my wiper spray. I also think ditching your wiper spray (even if you use it) is a small price to pay for a nice meth kit. You can also run a small, separate container for meth, and retain you amazing windshield cleaning system, lol.
Old Mar 27, 2007 | 02:38 PM
1INSANEGTO's Avatar
to each is own. I drive my car everyday 70miles min a day with A/C and all. "True Street" car.
You do it one way I was just trying to pass on my info.
Old Mar 27, 2007 | 02:45 PM
ninetres's Avatar
Werd. I daily drive my car too. Rain-ex wax for windows works wonders at 40+mph! And some brand new cars don't come with AC.....so I think cars without AC can still be considered street cars
Old Mar 27, 2007 | 03:11 PM
MIGHTYMOUSE's Avatar
i'm not a specialist but i do spray my methanol on my windsheild when it is dirty.. it gets clean and smells good too!
i also run straight meth in my snow pump, but have only been doing it for a couple years now so it is probably messing something up
here is something to debate.... me personally when i spray meth i PULL gasoline out to retain the a/f that i want.. as opposed to setting the a/f where i want and then letting the meth push the a/f waay fat. how do you feel about that?
Old Mar 27, 2007 | 03:14 PM
cablebandit's Avatar
thats what i did Dave.
I used straight meth in SMCs little ford efi pump and also in a shurflo from Northern tools...no probs out of either
Old Mar 27, 2007 | 03:38 PM
1INSANEGTO's Avatar
I have a holley blue fuel pump that I am sure would work on a meth kit also. never thought about it.
Old Mar 27, 2007 | 03:58 PM
SSilverSSurfer's Avatar
Originally Posted by LittleRedZ
intercooler=restriction+weight
i dont think its a bad idea if you dont drive the car on the street much.
The mustang guys do it all the time in a power adder class, and limited cubic inches to get every bid of power they can
have at it and let me know how it goes, you make a good point
Old Mar 27, 2007 | 05:03 PM
  #32
LittleRedZ's Avatar
it has been done before by many so its not like i'm pioneering something new
http://www.musclemustangfastfords.com/tech/0407mm_snow/
Old Mar 27, 2007 | 06:35 PM
  #33
i understand, i dont plan on running in any classes that only allow one "intercooler" type deal, thats why im running an intercooler and a meth kit. but like you said weight savings and restrictions then go for it,
Old Mar 27, 2007 | 06:50 PM
  #34
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I have noticed pure meth leaves streaks on my hood when I use the WW function. They do just wipe right off, though.
Old Mar 27, 2007 | 07:58 PM
  #35
Frost's Avatar
Good reason NOT to buy a cheap pump. Alkycontrol's pump was MADE for handling pure methanol. As MM said, he hasn't had issues with pure meth in his Snow pump either.
For the guy who wants to run meth and no IC... it will work GREAT. If you run pure meth (people STOP with this washer fluid ****; if you're gonna do this, why not reap the octane reward?) for your IC, your IATs will be BELOW AMBIENT. NO AIR TO AIR INTERCOOLER CAN DO THIS. Here is a quote from a post I made in another thread that has LOGS that show what I'm saying to be true:
Originally Posted by Frost
Bah; get meth
First log here of a S/C car with no IC @ 7psi, pulling through 4th gear. Locate the IAT in the second group of pens on the left at 174 degF. This was on a 95ish degree day. Notice the 12deg of timing. Don't look at the speed
Here is the next log with some meth. The IAT pen is green on this cap. Look at the IATs below ambient... and look at the difference in timing.
Old Mar 27, 2007 | 08:09 PM
  #36
Good reason NOT to buy a cheap pump. Alkycontrol's pump was MAD for handling pure methanol. As MM said, he hasn't had issues with pure meth in his Snow pump either.
so it gets better with an IC and meth?
Old Mar 27, 2007 | 08:48 PM
  #37
Frost's Avatar
That's not the point though. He wants to know how will the meth work with NO INTERCOOLER. That's what I showed him.
Old Mar 27, 2007 | 09:10 PM
  #38
LS1injection's Avatar
Yes the car will run great with methanol injection and NO intercooler, the cooling benefits will keep temps down. I am with Frost, i believe in 100% methanol, VP M1 is the stuf, The Alky control pump can and will handle pure methanol.
Old Mar 27, 2007 | 11:52 PM
  #39
i was asking does it get better having an intercooler and meth? i would imagine so but i thought i would ask
Old Mar 28, 2007 | 08:33 AM
  #40
LittleRedZ's Avatar
intercooler=restriction=less power
i guess it would be better for the street driving, thats about it.
