Computer to use with FI
David
It has me thinking about unloading the GEN 7 DFI and going witht he AEM plug and Play. At $2500 its still cheaper than BS3 after you factor in trans control and theier guage add on adapter and such.
Just some info I thought I would pass on.
Heck my single bar MAP sensor in my LT1 is tuned like a champ and I'm running 16#'s of boost.
But whats out there that will allow you to keep stock gauges? AEM does I believe, but does BS3 or FAST?
Thanks
Casey
I have seen and also like AEM. A couple of my good friends around here have GT47-88 powered supras so i have seen the software alot. The features that it provides is impressive, especially considering you just plug it in. I would like to see the set up in an f-body, but i think that if i was going after market i would want a computer to control my race car that i drive on the street.
Thats why if i replaced my ECU i would go with BS3 or a FAST system. IMO they have the features im looking for without all the unessacarry fluff.
I have personaly used: HPTuners, EFI LIve with a RoadRunner, FAST, GEN 6 and & DFI, BS3, AEM, and Motec. Motec only once though. BS3 works awesome. GEN 6 i like until I used GEN 7 and I love it. HPT and EFI Live work well with the stock PCM. Motec was crazy. AEM is my over all favorite. When their plug and play box is released I will have it. Period. Its the only reson I am keeping my stock wiring harenns and guage cluster.
So BS3 or FAST wont allow you to keep your factory gauges? By saying the only reason your keeping your stock wiring harness and gauge cluster?
Coming from the supra world I know with AEM you can retain the factory gauges. Hince, plug n play
Casey
Casey
1/2 way down the page......
http://www.ls1speed.com/catagory.cfm.../%20Electrical
BS3-004-001 Big Stuff 3 Gen 3 Pro SEFI $2399.99
IZM798 Speed Inc - LS1 F-Body Big Stuff 3 Harness $769.99
At WOT the computer would not have any problem geeting the proper fuel.
The 99+ have a "dual write" code, non singular, that is why you see most of the tuning handheld stuff for the 99's and nothing for the 98's. I went BS3 cause i needed plus 15psi, afr targeting boost control, 4l80e controller and stock gauges... and i just didn't want to deal with the 98pcm...
