My good luck has ran out...
Old Mar 25, 2007 | 09:37 PM
  #41
Tiago's Avatar
Originally Posted by Inspector12
HEy Tiago are you running the L-19 studs cause they have fixed a lot of poeple's problems that were lifting heads etc...? If not you might go ahead and throw some on there and now you know where most of the metal you find on your drain plug was comming from (Valves, Keepers, and rockers) I bet the bottom end is fine.
I don't think my studs are L-19 so that is something to follow up with.
Yea Im glad that I kwow where all that metal is coming from thanks for the tip
Old Mar 25, 2007 | 09:39 PM
  #42
Tiago's Avatar
Originally Posted by kp
The AFR valve thing kinda sucks, I hope they recalled all the heads that were still on the shelf and checked them. Mine were just bought but they were on the shelf for a while.
At least you will get a fresh set of heads back for no cost, lucky you didnt drop a valve..
very, this may very well have been a blessing in disguise.
Old Mar 25, 2007 | 09:55 PM
  #43
JMBLOWNWS6's Avatar
Ive got a pair at AFR for the same thing also.
Old Mar 25, 2007 | 10:10 PM
  #44
LASTLS1's Avatar
6 Second Club Moderator
Head studs, special gaskets, copper coat, once you get to a power or et level, nothing keeps the 4 bolt heads down. I'll let you know about the copper- o ring soon. If he tries to turn up the boost and get to the mid eight power level, head gasket won't stay sealed. These 4 bolt heads are killing us!!
Old Mar 25, 2007 | 10:43 PM
  #45
JJSimon904's Avatar
Definitly blessing in disguise man!! Can't wait for a ride after you "freshen" it up.
Old Mar 26, 2007 | 05:24 AM
  #46
Inspector12's Avatar
TT-TECH Veteran
Originally Posted by LASTLS1
Head studs, special gaskets, copper coat, once you get to a power or et level. Nothing keeps the 4 bolt heads down. I'll let you know about the copper- o ring soon. If he tries to turn up the boost and get to the mid eight power level, head gasket won't stay sealed. These 4 bolt heads are killing us!!
I know that it won't fix everyone's problems, but it has fixed it for some and is another somewhat of a cheap mod to help make his head gaskets last possibly longer and stay down better etc...
Old Mar 26, 2007 | 07:41 AM
  #47
NA$TY-TA's Avatar
Damn buddy... was bound to happen....we all know it when we try and push these cars hard.....
Old Mar 26, 2007 | 09:13 PM
  #48
Tiago's Avatar
here is a pic of one of the valve heads wore down, this is the worst one:
I'll be contacting them tomorrow.
