Incon & K-Member
Old Mar 26, 2007 | 07:16 PM
ChevyNo1's Avatar
Default Incon & K-Member
I've done a search and can't come up with what I'm looking for . . .
What k-member ( if there are any ) will work with the Incon setup with no modifications? I know BMR at one time had one that worked, but do they still? I'm going to call them tomorrow but wanted to see if anyone on here knew . . .
Thanks!
- Dug
Old Mar 26, 2007 | 08:29 PM
bowtieman81's Avatar
Curious to know this as well.
Is it required to modify the stock k-member?
Old Mar 26, 2007 | 09:11 PM
Mike 01WS6's Avatar
Works with the stock K just fine
I wasn't aware it wouldn't work with any aftermarket K at all. The point of an aftermarket K member is to give you more room to work with. I believe all K members will work with the Incon. From looking underneath several times, there is no problem with an aftermarket unit.
Old Mar 26, 2007 | 10:01 PM
anarchy99's Avatar
I had to clearance my BMR k-member for my kit to work. Everything fit around it, but one of the intake hoses wouldn't go onto the turbo with the BMR k-member for some reason. Tried a couple times and everything was right so we just supported the car, dropped the k-member out, cut the corner off and welded a piece on it where we cut and it looks factory. Not sure if I'm the only one that has had to do this, but I've taken the engine off the k-member several times both in the car and out of the car and everytime it lines up the same. I'll see if I can dig up the pics of where we cut it.
Old Mar 26, 2007 | 10:08 PM
TwnTrboCE's Avatar
It's been a while, but I believe the problem was on the passenger side. The rear mount for the lower control arm. On some k-members this was square on the inside. Where the factory is round. The Incon kit is real close on that side. I think they make them now with the corners clipped off at an angle.
Old Mar 26, 2007 | 10:13 PM
anarchy99's Avatar
Yeah, I'm pretty sure that's exactly where we ran into the issue and that's all we did was take the corner out.
Old Mar 26, 2007 | 10:22 PM
onfire's Avatar
Coal Mining Director
I don't have the newest version of the BMR k, but do have a newer version....no problems at all with the Incon.
Old Mar 27, 2007 | 12:07 AM
ChevyNo1's Avatar
Thanks a lot guys! I'll give them a call as well tomorrow . . . anarchy99 if you do come across those pics I'd like to see them.
- Dug
