pics of my setup...
Old Mar 26, 2007 | 07:58 PM
Roadie's Avatar
Default pics of my setup...
I don't post over here a whole lot, but thought I'd share a few pics of my build. I know... I know... It's a lowly LT1... But it runs now!!!
8.65:1 355 shortblock (Eagle 4340 crank & H-beams, SRP pistons)
stage 3 Trickflow heads
220/230 on a 114 LSA
T-76 Q-trim
ceramic coated hot parts (thanks RealQuick!)
ATI twin high-flow intercoolers
TiAL 50mm BOV
38mm wastegate
FAST
White Racing PCB
Delteq, MSD DIS-4, NGK 4554 plugs
custom dual in-tank Walbros, custom rails, -8an/-6an feed/return, Aeromotive FPR, 75lb/hr delphi injectors
supporting mods:
T-56, B&M Ripper & McLeod street twin
3" HD steel shaft
Moser 12 bolt & TA cover
Spohn TA
13" Baer brakes
Suspension Techniques sway bars
Hotchkis STB
Hotchkis springs & Bilstein HD shocks
BMR PHR Relo kit
custom LCAs, PHR, LCA relo brackets
etc. etc. etc.
I soooo need a polished alternator...
Old Mar 26, 2007 | 08:03 PM
SSilverSSurfer's Avatar
nice stuff, its ok that its an lt1 you didnt know better, jk
Old Mar 26, 2007 | 08:12 PM
Snyper's Avatar
is it fast?
Old Mar 26, 2007 | 08:16 PM
Boo"SS"t's Avatar
Looks pretty good! How much boost? What are your manifolds made of? and have you dyno'd yet? BTW, is that a SLP cold-air intake? if it is...that's pretty clever!
Old Mar 26, 2007 | 08:20 PM
Roadie's Avatar
Originally Posted by Snyper
is it fast?
We'll find out soon... Still needs some tuning, but it runs and drives at least. It'll be fully tuned as soon as my FAST box comes back (had some issues with the box and I have a loaner one on there now).
planning to run 10-20psi depending on what I'm in the mood for. Normal cruising will probably be 10psi, but I can just hit a few buttons on the eboost2 to change my mood.
The manifolds are mild steel logs. 2.5" passenger side log, 2.5" crossover, 3" driver side log, and 3" downpipe. The wastegate hangs off the crossover pipe and vents to atmosphere. I'll post a pic in a few...
Old Mar 26, 2007 | 08:24 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
CORRECTOMUNDO. ................
Old Mar 26, 2007 | 08:27 PM
Roadie's Avatar
Old Mar 26, 2007 | 08:33 PM
ZL1Killa's Avatar
thats pretty freakin sweet man. i love the way your paint looks with the flames
 Michael S. Palmer
Old Mar 26, 2007 | 08:38 PM
Roadie's Avatar
oops. forgot to answer... Yeah, it's a SLP CAI, grafted on the ATI twin-high-flows and the TiAL flange welded on.
Old Mar 26, 2007 | 09:18 PM
Frost's Avatar
Might have overboost/creep issues with the gate like that... at least it looks like it. Nice damn car and setup though.
Old Mar 27, 2007 | 01:46 AM
chuntington101's Avatar
Originally Posted by Roadie
did you do that or get them fabbed up???? great workeither way.
thanks Chris.
Old Mar 27, 2007 | 07:22 AM
smokinHawk's Avatar
looks nice, very clean.
Old Mar 27, 2007 | 07:45 AM
99Z28LS1's Avatar
very nice man, real nice looking kit
Old Mar 27, 2007 | 08:23 AM
SRZ's Avatar
SRZ
What kind of issues did you have w/ the box? You are running and XFI or the original FAST box?
Old Mar 27, 2007 | 10:40 AM
Roadie's Avatar
RealQuick did the hotparts in his garage. I took care of the engine, cold side, and rest of the stuff so that we'd finish about the same time (he still beat me by a few months).
it's the old (classic) box. It wouldn't see the low-res signal from the opti at all... showing 0 rpm while cranking. therefore, it wouldn't trigger the injectors or spark. I borrowed a box from Jon (RealQuick) to troubleshoot. I unplugged mine, plugged his in, dropped the base tune in, and his fired right up.
Old Mar 27, 2007 | 10:45 AM
Roadie's Avatar
I hope not, but it's in the back of my head... i'm actually more worried about the ATI twin high-flows being able to flow enough air and not be a bottleneck.
There are some compromises with this setup because I didn't want to ditch accessories or hack up my front bumper.
Old Mar 27, 2007 | 11:20 AM
THE_SUPRA's Avatar
looks cool buddy!
Old Mar 27, 2007 | 11:45 AM
DeltaT's Avatar
Very nice. I like where you stashed the coils.
Jim
Old Mar 27, 2007 | 12:24 PM
TURBO383WS6's Avatar
damn, that's a clean setup. any closer pics of the fuel rails and regulator you could email me? i'm about to work on the fuel side of mine. i've got plenty of fuel at 20psi w/ the dual walbros and stock lines w/ 72# injectors, but i'm about to upgrade to be on the safe side. also, are you gravity draining the turbo or do you have a pump? we've got pretty similar setups.
Old Mar 27, 2007 | 12:49 PM
Roadie's Avatar
The turbo is gravity drain. It's just barely high enough to have a downward slope all the way to the pan.
Here's a few pics of the pumps (before putting the hose clamps on the pump outlets) and fuel rails... I went overkill on the wiring
Also, I used a few extra fittings on the rails to keep the FRP as close to the front as possible to keep the STB running behind it. You can get by with a lot less fittings or using some hard line bent around to accomplish the same thing:
