Ohio Forced Induction
Old Mar 28, 2007 | 09:13 PM
tt427ls1's Avatar
LS1TECH Sponsor
Originally Posted by GotV-8
He said we will take care of it......I ordered new wires today and I dont think I should have but he didnt offer. So that was 70 bucks I shouldnt be spending. If they do it again, something will be done to fix it or there will be things done to make it get fixed.
Ill see if i can get a pick up real fast.
Yah on dustins the wires did touch after we gave the car back to him. I drove it around and they were fine. I guess after time the zip ties got weak. I am taking car if that. I would like to try and find some medal zip ties or just move the coils up a little. I am going back to his house 2.5 hour away on monday to take care of this issue.
Jerry your stuff shipped...I will pm your numbers to you.
The website is ohioboost.com....thats the new one. Ohio forced induction is going to be forwared to that address.
Old Mar 28, 2007 | 09:28 PM
02SSLE's Avatar
go with 6.0 truck coils supose to be a little hotter spark and also they set quit a bit higher on the valve covers.
Old Mar 28, 2007 | 09:31 PM
ozws6's Avatar
Originally Posted by Boo"SS"t
do you have to do anything special to be able to use the truck coils? or just plug 'n play? what year truck? where's the best place to buy them and how much? -thx!
The coil pn# is 12558693. They are the square mitsubishi truck coils for the 6.0L truck. I think they were used on the 6.0L trucks up thru 02-03. You'll need the coils, coil bracket, and bracket harness as a unit. It will bolt right on and plug right in like stock. I picked up my set off e-bay for $150. Do a search on the coil pn and you'll find all kinds of info.
Old Mar 28, 2007 | 10:06 PM
cablebandit's Avatar
hmmmm....so new coils are a must i guess. seems like metal ties against the coil bracket would ground out or burn thru quickly
Old Mar 28, 2007 | 10:22 PM
a vortech ls1 kit i messed with once on a 98 fbody had some little offset things that moved the coil packs up......i have ls2 coil packs so i think i can make mine work....we will see.
Old Mar 28, 2007 | 10:33 PM
looking at the pic....you could take out the bottom bolt for the ?#3? coilpack and try to rotate the bottom towards the front some...one bolt will be fine....most folks #8 doesnt have the top bolt reinstalled if you ever have to fight to get it out. dunno about #5
Old Mar 29, 2007 | 01:42 PM
740racing's Avatar
Dont forget the old headers Joel.
So far your customer service is the best I have ever seen. Multiple 2.5 hour drives to fix a car, that goes along way in my book.
