Tweaked my budget kit
Old May 9, 2007 | 08:04 PM
RICE ETR's Avatar
Turbo Addict
So i finally took some pictures of everything put back on the car. The sway bar does fit but i just removed it...I ran it all last season so going to try it without this year.
The DP for the wastegate looks crazy because i was trying to quiet it down and that's the only piece of tubing i had so i made it work.
Overall the car spools noticeably quicker, there is less heat under the hood, the car is surprisingly quieter due to the wrap and the extra tubing on the WG.
I have pictures of the Th400 swap too....but i will put those up in the auto section.
FWIW, having to drive the car in the snow that one day and exposed to all the salt/chemicals really rusted everything up...yuck!
Ok, critique away.
Old May 9, 2007 | 11:20 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Ok, for some odd reason my post isn't showing up. I tried reposting and it says the post is a duplicate of another post already posted. ????? Trying this instead.
I don't know where or how I clicked on this link. I just noticed the last post was 4/2/07, so sorry for necroposting. I'd like to see how this looks, but...
EDIT: I can see it now. For some odd reason it wasn't showing this had a second page. Then I had all sorts of weird things happening when I tried to post.
EDIT YET AGAIN: What sized turbo is that?
Old May 10, 2007 | 08:10 AM
smokinHawk's Avatar
i can see it.
looking good.
the first set of pics are gone though
did you do anything to your radiator or just changed it to a pusher set up?
Old May 10, 2007 | 09:20 AM
RICE ETR's Avatar
Turbo Addict
Thanks.
Yea i moved the first pics around so the links don't work, I'll fix that later.
The radiator is all stock and in the stock location...just put two Spal pusher fans on.
Old May 10, 2007 | 09:21 AM
RICE ETR's Avatar
Turbo Addict
Oops, ...it's a precision 76GTSH
Old May 10, 2007 | 03:45 PM
frcefed98's Avatar
Do you have any pics of it off the car, manifolds to crossover etc...
J
Old May 11, 2007 | 05:16 AM
RICE ETR's Avatar
Turbo Addict
I looked last night for pictures of it laying on my garage floor but couldn't find them...so no dice as of yet...sorry
Old May 11, 2007 | 07:46 PM
OWN3D BY MY PROF!
Could you have brought the merge for the cross over slightly higher up to allow for the use of the stock fan assembly? Or a puller fan setup?
Old May 13, 2007 | 05:57 PM
black98ws6ta's Avatar
Probably not...there is very little room to fit the turbo inbetween the motor and fans with stock fans. However install pusher fans and you have lots of room.
