sound of t76 on a truck manifold kit?
How loud can i expect my 5.3 with a truck manifold kit and a ball bearing t76 to be it will be running a 3.5" downpipe to the diff where it will be run through a race magnum and dumped......will it have the huge whistle etc?
prolly pretty quiet. im not sure descibles or anything but the turbos do quite a bit of muffling, plus the truck manifolds and a race muffler...id say pretty quiet.
its gonna be loud when your in boost. Mine was originally to atmosphere, but i didnt like it cause i couldnt hear what the motor was doing WOT. but your going to hear the pshhhhh of the wastegate, not the whine of the turbo
http://video.ls1tech.com/search/supe...e40121ab04.htm
http://video.ls1tech.com/search/supe...390021e16f.htm
I have a straight threw bullet muffler.If you run a chamberd muffler it will be very quiet
ported compressor housing or not? I'm running a non ported T76 with truck manifolds and its very quiet, turbo whine is almost non existant.
When I was running a GT42 with a ported compressor housing, but other wise identical set up, the turbo whine was insane even from a take off.
J
J
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
LS1Tech Co-Founder
The exhaust with a Dynomax bullet will be kinda loud. I don't think it you will hear the turbo at idle that much. I have a GT47-88 with a 4" dp and bullet and I think it sounds like a cammin' dump truck at idle.
so would it be louder with the wastegate to atmosphere or back into the downpipe , i love the turbo whistle and dont want the thing to sound like a tactor
With the WG dumping to atmosphere, you'll hear a sound like rushing water coming from the front of the car when you hit the WG's spring limits or where you have your BC set at.....PSSSHHHHHHH!!!+turbo whine. If its routed back into the DP all you'll hear is the turbo whine.
i have a T-76 Q-trim and haven't finished my exhaust yet. Driving it around town, not even in boost, the turbo whine is so loud that it seriously completes with exhaust sound through the open downpipe. It's the furthest thing from a sleeper...
I think a lot of it depends on the turbo and air filter setup (my filter is nothing but a race screen).
