New Dyno#'s - WTF is Going On?
I have the LT1 unit, and I know the ATI setup from the factory is very restrictive, as it cut 6#'s of boost and over 100 RWHP from my dyno runs with and without it on. Just something to think about especially if it is flatlining up top. Other things to consider is your gap size on your plugs, as if it is too big, you could be blowing out spark (also been there and done that). Mine is currently gapped at .28 but originally it was a larger gap, and I couldn't seem to get any power up top because it was blowing out the spark.
Just a few suggestions. I hate chasing problems like this. I have been through it all before and it really sucks. I hope you figure it out. Good luck!
I'm hoping to answer all the questions at once - here's a few pictures that might help.
1st - the air intake for the blower. It's a custom 4" tube thats been welded to the front of the blower and runs all the way to the passengers side to a very big K&N that you can't see in the photo.
2nd - The can has been tuned with HP tuners in the past and had the same falloff and now I'm running BS3 with the same problem, so I don't believe its the tune
3rd- There is no belt slippage - checked the data log and its right on the money - amazingly, no slippage.
4th - Carl, its a 3 bar
5th- the 2nd photo show a custom Spearco intercooler. The nitrous test refered to above was done with the stock twin coolers - have not tried it with the new intercooler.
I did speak with Greg from AntiVenom and he said that it could be lifters and push rods- I'm running stock on both. Any thoughts???
I hope this helps
Peak #'s are for Dyno racers
If you want more "peak" #'s you have to change the Cam or raise the comp. or run alot more boost. To me that setup looks real good.
http://forums.corvetteforum.com/show....php?t=1677877
run a BIGGER cam and then ditch the fast intake. i ran the fast before. took some tuning to get the idle good. but after getting the gmpp setup, my idle is great starts up no problem/ doesnt hunt to catch the idle. and @9 psi i have the same hp as you 707rwhp @ 6300 rpms. i cant imagine what mine will hit if i pulley it to 13-15 psi.
btw: im also running true duals through cats and "4" mufflers classic chambered and magnaflows
Boost is the easiest way to add the power. Try to pulley it to max out the blower.
