A few ?s guys
Old Apr 8, 2007 | 05:05 AM
flippincamaro's Avatar
Default A few ?s guys
Ok I just bought a turbo from a local guy for cheap, It is a Airesearch turbo I assume by garrett since the plate on the turbo says it, ok the sizes on it is as follow, It appears to be a hair bigger than a T4 flange but not much, the inlet is a four inch the compressor outlet is a 2 1/2 and the exhaust outlet is a 3 inch, The exhaust housing says it has a A/R of 1.58, How much horsepower is this turbo good up to? I am wanting to put this on my 6.0 on about 10#s of boost like i had my twins at.I am mostly concearned about the 3inch exhaust outlet is that enough? Any help would be great, Thanks guys
Old Apr 8, 2007 | 09:15 AM
coop5885's Avatar
you need to pull the compressor cover and measure the inducer(the wheel you can see through the intake) and that will tell you what size your wheel is. Thats a large hot side A/R sounds almost like a GT42 or GT47.
as far as i know the flange could only be a T4 or a T6. If your not that good with turbo stuff, send it to jose(forcedInductions) and he can tell you what it is, and if its in good shape
Old Apr 8, 2007 | 11:44 AM
Thanks man, Well I have a t4 flange in my garage and the bolts holes are just a hair off, So I assume it is a t4 flange, What part of the wheels should I measure the bottom of the wheel or just the part that shows on the compressor side? Hey i got one more ? how come my buddy has a huge turbo with a 5 inch exhaust outlet but his A/R on it is a 1.34, and looks way bigger than mine? How is that? Thanks
Old Apr 9, 2007 | 12:31 AM
I need some more info please? i measured the compressor wheel and it measured 2 1/2 up top and at the base it was 3 1/4,
Old Apr 9, 2007 | 09:31 AM
DrTurbo's Avatar
LS1TECH Sponsor
Its a 64mm turbo with a 1.58A/R. It will probably be a little laggy and die around 500-550rwhp.
Old Apr 9, 2007 | 01:42 PM
Thanks DR.Turbo that is what I needed to know, I can use it for a little bit then, Will it be big enough on the exhaust side for the 6 liter on about 10#s of boost since it has a 3 inch outlet for the exhaust?
