is it an issue?
Old Apr 8, 2007 | 10:45 PM
otherwhitemeat's Avatar
Default is it an issue?
is it possible to run a 1 3/4 header on one side and a 1 5/8 header on the other side with a turbo charged motor and not have any problems?
Old Apr 8, 2007 | 10:50 PM
DMH Fabrication's Avatar
Why not just run the same size on both sides? It makes no sense to run two differnt size primary tubes.
Old Apr 8, 2007 | 11:18 PM
gogogadgetcar's Avatar
if you have the capability to tune each cylinder ya sure you could pull it off probably but as stated above... why?
Old Apr 9, 2007 | 06:10 AM
engineermike's Avatar
Couldn't be any worse than running a tubular on one side and a log on the other and that works fine, even without the ability to tune each cylinder.
Mike
Old Apr 9, 2007 | 05:57 PM
Mike
ya thats what i figured too
Old Apr 17, 2007 | 05:03 PM
orange88's Avatar
what the hell are you rigging up now
Old Apr 17, 2007 | 05:04 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Question
Mike
Can u run a stocker log manifold on 1 side..and a LT header on the other side.??? .....on my internally stock engine.[asking because emmissions MIGHT check location of cats--pass. side is fine.]
Old Apr 17, 2007 | 07:32 PM
Are you still running both sides through the turbo?
