Who has BEST PRICE on F1C Procharger System?
Old 04-14-2007, 05:32 AM
EPP
EPP's Avatar
Question
Originally Posted by SpdFrk1990
I seen a LS1 gto tonight with a procharger made me want one soo bad! He had kooks headers, heads, cam and a few other things also but a stock intake/tb and I think the dyno sheet was around 568rwhp or so if I could remember. Would I be able to make that kind of power safely on the stock bottom end then?
That sounds like Carl's 2004 GTO that we recently fininshed. I don't like to see rwhp on my Mustang Chassis Dyno much above 500rwhp. Carl knows it is a bit too much. Bob
Old 04-14-2007, 11:54 AM
SpdFrk1990's Avatar
Cool ill have to ask him and if I decide to go with a procharger ill give you guys a call.
Old 04-14-2007, 05:04 PM
EPP
EPP's Avatar
Thumbs up
Cool, thanks, I appreciate it! Bob
Old 04-14-2007, 07:59 PM
Outlaw1's Avatar
Any idea if there is an off the shelf bracket setup for an F1R that would work with an LS1 in a first generation Camaro? Links/pics?
Old 04-15-2007, 11:40 AM
EPP
EPP's Avatar
Question
I think the GTO bracket assembly
looks to be the best fit in the 1st gens, although we haven't tried one yet. We do have an original '69 Z28 that we are finishing up installing an '05 LS2 from a wrecked GTO into. I'll have to do some measuring.
ATI offers the GTO kit with an F1A, but I doubt the 8 rib belt assembly would be enough for an F1R. http://www.exoticperformanceplus.com...html?item=1070
How much power are you looking to make? An F1A will make quite a bit of horsepower. Bob
Old 04-15-2007, 01:52 PM
GrahamHill's Avatar
Originally Posted by GrahamHill
Do you guys carry (or can get) the F3R and 9.8" deck BBC brackets?
Old 04-16-2007, 05:28 AM
EPP
EPP's Avatar
Smile
Yes, we can get anything that ATI produces. Thanks, please send me a pm on the parts, so I don't forget to get back to you on a price. Bob
Old 04-16-2007, 04:08 PM
GrahamHill's Avatar
Done.
Old 04-17-2007, 05:13 AM
EPP
EPP's Avatar
Smile
Done.
I'll get back with you today. I have 10 pm's to go through this morning before the phones get busy. Thanks. Bob
Old 05-03-2007, 10:23 AM
MrDude_1's Avatar
my (untried) idea from measuring local cars.... is that a C5/C6 bracket, shimmed out to match the crank pulley, would fit and work best.
the nice thing about it, is it uses that unused space on the passenger side of the car, rather then trying to stuff everything over on the drivers side.
Old 05-03-2007, 12:18 PM
Outlaw1's Avatar
I have my blower mocked up with an F-body setup. It takes clearancing the subframe and aftermarket or modified stock control arms because it gets very close to the front mounting point, solid motor mounts will be a must. In my case it's not an issue, I was planning on aftermarket control arms to clear my relocated manual rack and I have Moroso solid motor mounts anyway. In just a few months the car should be running.
Old 05-04-2007, 05:04 AM
  #32
EPP
EPP's Avatar
Question
Would there be room for the inlet side of the plumbing? Bob
Old 05-04-2007, 10:33 AM
  #33
bandit1's Avatar
Well i made 632 rwhp with 11psi on stock bottom end didnt last that long I was told 500 rwhp is where you want to stay around.
Old 05-04-2007, 11:25 AM
  #34
LS1Tech Sponsor
Slowhawk's Avatar
On a 1st gen there is no need to mount the blower in a newer F-body location.Mounting it up on the side of the motor is alot better for belt support and routing of pipes. We've built numerous small block/big block setups in 1st gens or Malibu's .You want the blower up high.
Old 05-04-2007, 11:51 AM
  #35
MrDude_1's Avatar
yea... theres a ton of room there.
its the routing to the intercooler that i really dont know.. without a car infront of me, i cant visualize a mockup with any accuracy.. mostly its the usual problem of how to get that tube up front to the intercooler with the subframe rails in the way.
Old 05-05-2007, 06:54 AM
  #36
EPP
EPP's Avatar
We just finished putting an LS2 into a 69 Z28. It looked to me that the ProCharger GTO kit would be the closest one to making it work with the fewest hassles. Sort of what we did on this car. http://www.exoticperformanceplus.com...Car.php?car=22 Bob
Quick Reply: Who has BEST PRICE on F1C Procharger System?
