Supercharger Surging @ Idle
In SD, idle and part throttle tunes out perfectly. The moment I re-enable the MAF the fuel trims peg out to +25%. Via RTT, I've added in approx. 256% more to the stock values to the MAF transfer (for this particular MAF) just to get the fuel trims to come down. That's insane! Just to give you an example, at 1500 hz the value is 3.64 g/sec, whereas the stock transfer value for that MAF is around 1.42 g/sec. We either have a fairly large vacuum leak, which I tend to believe is the issue, or either this car is just going to have to be tuned in SD period.
As a side note, the Idle Desired Airflow is reading quite low (around 4.xx to 5.xx g/sec), which is much lower than I would expect, even when the STIT isn't really indicating any adapting to keep the car idling (which idles absolutely great in SD mode).
This is what he posted a while back if this helps.
Just start upping the MAF numbers from 2000-6250hz until you ltrims fall in line at idle/part throttle. Problem is the where the MAF is located the air pretty much just 'stalls' there and the MAF barely sees any airflow at idle and lower rpm part throttle. Its nothing new really, I have tuned a few dozen ATI f-bodies and they are all the same..
Its also easily fixed..
But like I said its very common, used to be more of an issue before LS1edit and whatnot but these days a lot of guys SD tune or most know how to deal with it by changinf the MAF calibration down low a bit..
Haha... didn't you say you forwarded him this thread? Ask him how many SCs he's tuned.... He can swing the bias away from the MAF down low and more towards the VE besides just chopping the bottom of the MAF table. If you are running 9psi or higher though you really should think about 2bar tuning.
I ran the stock MAF for years with no issues other then changing a few numbers, most guys end up going SD/2Bar but since I had a 98 I kept the MAF and lied to the PCM - it never know any better
ORLY? On the PRO MOD it only surges when its FAT!Kevin is spot on ..Really it comes down to how big that baby cam really is .We run a pretty agressive cam in our ATI stuff,for one reason the customer wants the THUMP plain and simple. with that being said centrifugal superchargers are some of the most easiest things to calibrate as far as power adders go. They are with out a shadow of a doubt the most repeatable,constant "power adder " on the market.And they make for some of the most repeatable calibrations on the market today. As long as you have the basic criteria of injector slope you should easily be able to start and idle a procharged car.Once a constant Idle speed is obtained attack the the throttle blade set screw to get the IAC count in a reosonble realm and start your logs from there. There are plenty of threads about IDLE tuning and you should really have no problems.Honestly with the added airflow @ idle it makes them a peice of cake
