ProCharger guys...blow-off valve pics and specs please...
#42
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Originally Posted by Superado
Bob, I believe that you were correct in saying that the ProFlow is sufficient for my application. I spoke with ProCharger and was made aware that the style I have was changed to the ProFlow for appearance reasons mainly and maybe a little cleaner install...but that the reaction time of the one I have is actually a little better however. andereck got me the part # for the OE application of the vacuum control used on the one I have and I ordered one last night...it arrived this morning. He said that the diaphragm was replaceable, but for $9 my price...I may just replace the valve...it is just screwed onto the butterfly assembly. First I'm going to take the whole assembly off and clean and lube it really well and see if that solves the occassional sticking. If it continues, I will just change out the VCV. I probably should replace the little Summit filter I have on it with the K&N like you use or similar.
Thanks everyone for your input!
#46
I have the big Red Procharger Race by-pass and i'm already sick of it after only 1 day of driving the car. My car sounds like a giant snake driving down the road. I have a Mondo sitting here so I may have to swap over to it, Kp-what filter are using on the Mondo?
#47
#49
11 Second Truck Club
kp doesn't run a filter...
I got my new K&N RU-0160...I believe it will also fit the Mondo...
Originally Posted by kp
I used to filter...
#50
#52
cleaned up the "old-style" ProFlow bypass valve w/ carb cleaner...sprayed down the moving parts w/ SeaFoam Deep Creep for lubrication...re-installed w/ new K & N filter...so far, so good...
if the valve does stick again, I have a new Borg-Warner replacement valve waiting...I will just have to modify the "actuator arm" to match the modification that ProCharger does to make it operate the butterfly...
andereck...what is the procedure for checking the setting of the adjustment screw on the valve? Do you run it all the way in or out and then so many turns back or what?
#55
#57
Originally Posted by BigBenz
i want the loud ( super loud) swoosh noise and i dont have to weld. Any ideas. I have the twn instercooler kit.
#58
