alternator booster vs Boost a pump
Old Apr 23, 2007 | 05:34 PM
JAvenger007's Avatar
Default alternator booster vs Boost a pump
Curious if anyone has used the alternator boosters in place of a boost a bump for extra fuel.
I was considering adding one to my current fuel setup (racetronix/42lb inj). Goal for car is 500-550rwhp. Do I even need the boosters? If so, is the alternator volt booster good enough? Considering it switches on at WOT like a BAP, I'd think it would be fine, and with it being $200 less...its much preferred
Old Apr 23, 2007 | 05:37 PM
98turbls1's Avatar
I like the KB BAP that i have because it is boost referenced... As the boost goes up the voltage will too... It's more linear than an all or not type thing...
Old Apr 23, 2007 | 05:39 PM
kp's Avatar
kp
I use the voltblaster, little extra voltage for the ignition as well doesnt hurt. Its been on the car for two years and still works perfect. I didnt think it would hold up but it has worked out great.
Old Apr 23, 2007 | 05:52 PM
That was what made me interested as well. But the alternator booster is also referenced by the throttle. The more throttle the more it boosts voltage, so a full WOT run gets an extra 2.2v (and its PnP into TPS sensor). So i wonder if it delivers reasonable performance for its price difference and setup.
Old Apr 23, 2007 | 06:15 PM
rmpage's Avatar
Does an alternator booster overvolt the entire electrical system? Assuming it does, the concept does not impress me much. I would much rather overvolt the fuel pump directly.
Old Apr 23, 2007 | 06:47 PM
CALL911's Avatar
I have a brand new ATI Booster pump I'll sell for $100 shipped if you are interested. The stock fuel pump will not really support anything safely over 400 or so to the wheels.
Old Apr 23, 2007 | 07:10 PM
Jimmy P's Avatar
I have the volt blaster, and seems to work well.
Old Apr 23, 2007 | 07:21 PM
ATI sells a BAP? PM me some pics i'm be interested.
stock pump isnt the issue here, ive gone racetronix. But im wondering if just the racetronix is good enough for 500+rwhp in a daily driver.
Here is the casper electronics version that i'm talking about. Less than $100. Nice plug and play
https://www.casperselectronics.com/M...Category_Code=
is that pretty much same thing?
Old Apr 23, 2007 | 08:43 PM
MIGHTYMOUSE's Avatar
i have the caspers volt booster and like it helps me see the gauges at night when i floor it
Old Apr 23, 2007 | 09:39 PM
Tiago's Avatar
Volt blaster here as well... its like crack your electrical system...
Old Apr 23, 2007 | 10:10 PM
are you guys referring to the MSD volt blaster or the casper unit? Is there a difference?
Old Apr 26, 2007 | 10:25 PM
Superado's Avatar
11 Second Truck Club
don't know if there's a diff, but kp told me his is the Casper unit...
Old Apr 27, 2007 | 06:56 AM
msd and the kenne bell are fuel pump only, caspers is the alternator output
Old Apr 27, 2007 | 07:01 AM
Superado's Avatar
anyone know if this will work on the trucks?
Old Apr 27, 2007 | 12:36 PM
JASON11WS6's Avatar
Good questoin here... Does the voltblaster make your windows go up faster? I figure if it can make your pump work harder and your lights brighter maybe the crappy window motors will work harder.
Old Apr 27, 2007 | 01:10 PM
Tiago's Avatar
volt blaster is activated by WOT, 80% actually I believe, so unless you play with your windows at WOT... no.
Old Apr 27, 2007 | 01:18 PM
JASON11WS6's Avatar
That's fine the roll up slow enough were that might not be a bad idea!!!! Maybe I'll hook a boost a pump to them!!!!
Old Apr 27, 2007 | 01:33 PM
bboyferal's Avatar
LOL!!!
What? So our window motors could break more easily?
Old Apr 27, 2007 | 04:28 PM
so im still curious if the casper is giving considerable help for fuel (particularly a racetronix car). If it does a good enough job it seems to me that theres no reason to mess with a BAP.
Anyone have a link to Volt blaster?
Old Apr 27, 2007 | 04:50 PM
bcs's Avatar
bcs
I'm interested, I have a racetronix too. Would be nice to save a little.
