Where to mount Hobbs switch?
Subscribe
Apr 24, 2007 | 09:27 PM
I posted this in the fuel forum but I don't think it gets near as much traffic as hear and it's FI related too.
https://ls1tech.com/forums/showthrea...51#post6933951
Reply 0
Apr 25, 2007 | 08:25 AM
i built a tapped alimumum block that i Tee all my vacuum line fittings on it with 1/4npt, and i threaded my hobbs switch into that.
Reply 0
Apr 25, 2007 | 08:31 AM
Mines mounted on the butt pipe for the incons. Seems to work good there.
Reply 0
Apr 25, 2007 | 08:35 AM
Ok, a couple good options that I unfortunately don't have lol. I have the stock block and it's a procharger set-up. Is there some kind of T-fitting I can put in the brake boost line? I really don't have anyplace to thread the hobbs switch into as of right now. Where do the procharger guys normaly mount this thing?
Reply 0
Apr 25, 2007 | 10:56 AM
you will have to buy some brass fittings and barbs and make a point were you can thread them in, go to the hardware stores they will have all the pieces you need.
poutting it in the brake boost line will work fine.
Reply 0
Apr 25, 2007 | 11:11 AM
Quote: i built a tapped alimumum block that i Tee all my vacuum line fittings on it with 1/4npt, and i threaded my hobbs switch into that.
like this?
http://www.accountwizard.com/clients...tem&itemid=320
Reply 0
Apr 25, 2007 | 12:06 PM
ya similar to that
Reply 0
Apr 25, 2007 | 08:01 PM
check McMaster Carr
Reply 0
Subscribe
