Got Custom Hi-Flo dyno numbers with a little problem
The setup is:
*8.5:1 383 LS1 shortblock
*AI ported 98 heads (2001 technology
)*M6 w/ Mcleod Twin
*12-bolt w/ 3.42s
*Nasty sumped tank with A1000 (-10AN feed -8AN return)
*Vic. Jr. Intake w/ Nitrous Dave's elbow
*HF'er turbo kit with T76GTS and 4.5" Procharger intercoolers stood up vertical in grill openings
*and a bunch of other stuff
The first pull it made 465/480 with low timing and going a little lean. Second pull we bumped the timing by about 3 degrees and fattened it up to 11.0-11.5 and made 485/512. Third pull we tried to get the boost controller to bump the boost to around 12-13 but it would only give us #8-9 and pumped out 512/512. Last pull we opened the cutout and turned the boost controller up some more but it still would only make #8-9 but it put down 545HP (the tach signal screwed up and the TQ reading said 147 at 24000 RPMS. :lmao:
So we believe that it was just not getting enough load on the dyno and was spinning the tires since as soon as we pulled it out on the road and hammered down in 4th gear it jumped to #12. Looks like if we can get #12 and keep it from spinning it should make ~600 on pump gas.
Overall I'm pleased and it definitely feels stronger than 600 on the road. Also the Intercoolers are doing a good job keeping the IATs acceptable on a 86 degree day.
Cliff notes: It made 545 on #8-9 and wouldnt load up enough to get the #12 we wanted.
honestly i'd think those numbers would be higher.
is this on HPT 2bar
is this on HPT 2bar
ive got the same turbo and a 9:1 383 with a 3" FMIC and did 530 rwhp only revving to 5500rpms on 7 psi with 3* of burst knock and boost controller issues.what cam u running and any knock?
Kirk
Any help would be appreciated.
