Got Custom Hi-Flo dyno numbers with a little problem
Well my controller is not real complicated. You just turn 2 ***** to set your low and high boost level and select internal and external gate. I can make it make as much boost as I want the car just doesnt maintain it. It does the same thing running off the wastegate.
Mine does the same thing on every dyno I have tried except a mustang dyno. The mustang dyno I was on held boost all the way to redline my air fuel was just way off because of what might be a bad o2 sensor (I already swapped it but it didn't change anything and the light is still on)
