My Magnacharged SS almost done
Old May 2, 2007 | 02:12 PM
98'SS's Avatar
looks great man!
Old May 2, 2007 | 02:44 PM
Tracer X's Avatar
LS1TECH Sponsor
Looks good keep us posted!!
Old May 3, 2007 | 08:56 AM
BlownChevy's Avatar
blownerator
Is there any reason you are grabbing the IAT's at the inlet. I assume that is what I am seeing, correct me if I am wrong. The Magnuson NEEDs the IAT in the manifold to read discharge temps.
Old May 3, 2007 | 09:49 AM
gauge hp's Avatar
Nice, your gonna be so happy when its all done, mine was just finished about a month ago, it does everything maggie promised, I've never had that much horsepower with such good manners. Stock my car made 324 rwhp after the maggie and exhaust 477 rwhp @ 7psi, and you can always make more psi. ENJOY!!
Old May 3, 2007 | 10:01 AM
kp's Avatar
kp
Nicely done, I wouldnt mind having something like that for a driver.
Old May 3, 2007 | 01:30 PM
SideStep's Avatar
Old May 3, 2007 | 04:39 PM
BadMonkey's Avatar
They decided to go from there on my IAT's since I am only running 18* of timing and a 160 T Stat. During tuning they had no issues with this way as Ed explained to me and no KR, and it has yet to go over 210. If it hurts it or damages my bottom end so be it, I got another one in my garage. If someone wants it that way I am sure he will do it. Worked fine on my C5 with the procharger at 10-12 lbs with a stock bottom end, but then again the blower was before the IAT guage as well. He has had no issues with this method, so I am sticking to it for now. This is one of those debates that can go either way, its not my area or experiance so I will go with Ed I trust him on this. Honestly, I have no reason to change this for now, if there is an issue then I will try it the other way later on. Its not that hard to change later. I understand you think its a better way with you experiance, to go with the IAT's in the manifold. To an extent I agree, I even questioned it when I saw it that way myself. I am not pushing my car to its limit like some. We will push it to see what it can do on the dyno do but this is my daily driver. And we will back it down to be in a simple safe area. I will bump the boost with a smaller pulley for the track later this fall.
Old May 3, 2007 | 10:51 PM
farmdawg's Avatar
Old May 3, 2007 | 10:52 PM
farmdawg's Avatar
I agree with Damon
Old May 3, 2007 | 11:29 PM
ProjectCamaro's Avatar
I REALLY wish I had the money to do that to my car. I would in a second as that's the best type of blower, at least it's the kind I personally like the best.
Old May 4, 2007 | 06:23 AM
1FST99Z's Avatar
very nice, I am looking at doing the same setup in my car. looks awesome.
Old May 4, 2007 | 06:43 AM
  #32
lt1383's Avatar
damn nice !!
Old May 11, 2007 | 05:54 PM
  #33
-Freak-'s Avatar
how much has it effected your mpg?
Stump pulling torque would be soooooo nice to have.
Old May 11, 2007 | 10:46 PM
  #34
BadMonkey's Avatar
As long as I stay out of boost I should not loose too much MPG. In my C6 with the Magnacharger and Kook Headers I got 27 MPG in it on the highway. I figure with the cam heads and maggie I should be mid 20's. Right now my car is getting a 9" with 3.90 gears so I had to hold of on the driving till that is done. Plus I am going to be out of town all next week, by next week end it should all be done. Seats installed, rear, dyno springs etc.
Damon
Old May 12, 2007 | 02:40 AM
  #35
Rickys S/C Z28's Avatar
wow almsot make me want to seel my prochager!
Old May 12, 2007 | 01:04 PM
  #36
52172's Avatar
When you try and find out why the cruise controll is not working I know mine was not working once after a clutch install because there is a little switch on top of the clutch pedal under the dash that lets the computer know when the clutch pedal is pressed and it turns off the cruise control you might want to take a look at that switch and see if it is releasing. Might be an easy fix there. Gook luck car looks sweet!
Old May 12, 2007 | 04:02 PM
  #37
BadMonkey's Avatar
Thanks I will look into it. Amoung a few other things as well.
Old May 12, 2007 | 11:09 PM
  #38
Ed @ Late Model Speed's Avatar
I'll check out that clutch switch for you, we should be driving the car again by midweek, I'll keep you poste.
Ed
Old May 12, 2007 | 11:12 PM
  #39
marine02ss's Avatar
Ed u have a pm please respond,Thanks sorry for the hijack
Old May 12, 2007 | 11:37 PM
  #40
Sent one back Rudy, thanks
