spark plugs update
Old Apr 29, 2007 | 07:46 PM
cablebandit's Avatar
Default spark plugs update
I had a tr6 gasketed equivalent for my Darts but wanted a colder plug. I decided to use the NGK 7173...heat range 8....Mightymouse uses them and since he drives daily, his input was important. So far they idle very well...not QUITE as good as the -6 heat range but very close. They are exactly what i was looking for to go 900+rwhp at the track and still idle cleanly daily
Old Apr 29, 2007 | 10:22 PM
THE_SUPRA's Avatar
nice! thanks for the info.
Old Apr 29, 2007 | 10:57 PM
qqwqeqwrqwqtq's Avatar
Did you make a pull and check the plugs to see if they are in fact the correct heat range?
Old Apr 29, 2007 | 11:14 PM
obZidian's Avatar
right!!! kinda needed this info cable. What, do you think, changed while driving around with this -8 plugs?
Old Apr 30, 2007 | 05:02 AM
INTMD8 ....not yet...i drove my daughter home with them and thats been it...100 miles. I will see how they look after a few passes friday night.
obZidian...nothing seems to have changed but the idle quality and it is very slight....like going up 5 degrees on cam duration....best i can describe it
Old Apr 30, 2007 | 08:08 AM
smokinHawk's Avatar
good to hear your back up and running
i take it you need a gasketed plug for the darts? that you dont need for the stock and 6.0 heads?
Old Apr 30, 2007 | 09:48 AM
correct though the tapered seat plugs do seem to work on the darts
Old Apr 30, 2007 | 10:04 AM
Cool, let us know how it works out.
Old Apr 30, 2007 | 12:28 PM
MIGHTYMOUSE's Avatar
ive got about 10k miles on a set here, took them out for a new set when i swapped the motor to the trans am. its a good plug. the 3911's only lasted about 3k miles cuz of the short tab
