Is this normal
Old May 3, 2007 | 11:51 AM
Funkybird's Avatar
Default Is this normal
I was checkin out my piping the other day and noticed I had some black leak marks on my bypass valve so I cranked it up and just at idle both sides of the shaft are leaking ALOT! This isn't normal is it?
Below is a pic of the type of bypass valve i'm running.
Old May 3, 2007 | 12:52 PM
andereck's Avatar
It is normal to have some airflow past the shaft, it is so insignificant that it make no difference in performance and assures the valve doesn't stick.
Old May 4, 2007 | 10:29 AM
Funkybird's Avatar
Just to clarify, i'm talking about on the outside housing where the center shaft rotates is where its leaking out. Not past the valve itself on the inside. I don't think it should be?
Old May 4, 2007 | 11:06 AM
Fire67's Avatar
Just to clarify, thats exactly the part andereck was describing... Those valves all do that.
Old May 4, 2007 | 11:19 AM
hellbents10's Avatar
LS1Tech Sponsor
Is that a ATI one by chance, we have seen 1-2psi increases in boost pressure by going from that unit to there race bypass. Yes it is common for those to leak a good amount of air.
Old May 4, 2007 | 11:33 AM
Funkybird's Avatar
Yes it is an ATI, Thanks hellbents10!
