Any suggestions on why my car mississ and stutters???!!
make sure you have everything connecter right. Check injector wires. ( i forgot to plug a back one in and got a code) Spark plug wire sitting on the manifold? Make suure your wires are good. Also check wires near and tubing. does it tell you were the miss is comming from?
No it doesnt tell where its coming from. I baught new wires, I guess I am going to put the plugs back in and the new wires tonight. I have checked everything about 10 times everyting looks normal. I am going to take it back to the tuner to have him check everything again, but he seemed to think it was something ignition related.
Well put the new wires on. While I was looking everything over I noticed one of the 02 plugs clip was broke and the wires that feed into the plug were pulled out a bit, so I pushed the wires into the plug and then put silicone on the wires to hold them in the plug. NO MORE MISSIS AND STUTTERS THANK GOD. Tune will prob still need touched up cause in fourth its not perfectly smooth but a hell of alot better than before.
