Procharger Guys.....help
Old May 6, 2007 | 11:49 AM
AFASTYZFR1's Avatar
Default Procharger Guys.....help
FIXED IT................one of the intercooler pipes boosted off
Old May 6, 2007 | 11:56 AM
BigBenz's Avatar
did you put 60lb injectors on without a tune? i dont understand. o i get it do you have any gauges? How much boost r you runnig? Could be a milion things. r you getting any white smoke?
Old May 6, 2007 | 11:59 AM
AFASTYZFR1's Avatar
I bought the car with all the mods done and it was tuned..only 19k(miles)..+ I drove car 1,000 miles to get it home and didn't have any problem beside idle fluctuating a very small amount
Old May 6, 2007 | 12:01 PM
AFASTYZFR1's Avatar
I have a boost and fuel gauge....no smoke ......I think it is 8 lbs, but I have only gone to 4 or 5
BigBenz's Avatar
just the idle? If so that could be normal. You said it died?
Old May 6, 2007 | 12:02 PM
AFASTYZFR1's Avatar
actually....when I started it yesterday I saw a little white smoke....but it was cold and could have just been the normal smoke when its cold outside....?
Old May 6, 2007 | 12:03 PM
AFASTYZFR1's Avatar
yea.....when it hesitated I reved it a bit and then it cut off....I waited 5 min...and checked under hood and it started right up and I put it in the garage
Old May 6, 2007 | 12:43 PM
AFASTYZFR1's Avatar
Could it be something as simple as K&N oil from the filter on the mass air flow sensor....? I did oil the filter well....I am going to borrow the one from my Z28 and check it out....or go buy some cleaner
