PC STS Pipes
Old May 8, 2007 | 10:19 AM
rahmnja's Avatar
Default PC STS Pipes
Im in the process of buying a STS kit, is it unheard of getting the pipes powder coated say black insted of the silver color. Would it have any adverse effects on the system?
Old May 8, 2007 | 10:28 AM
JAvenger007's Avatar
the original kits (early designs) came with black piping. I have a few of them. AFAIK the black wont affect much, but I do wonder about it absorbing more heat.
Old May 8, 2007 | 12:32 PM
Nmbr1GMfan's Avatar
You could coat the cold side without issues, I coat lots of pipes for prochargers as well.
Old May 8, 2007 | 01:16 PM
HossinatorSS's Avatar
I think the cold side pipes have an HTC coating which is supposed to promote heat transfer to help cool the intake charge. Powdercoating might keep more heat in the intake stream.
Old May 8, 2007 | 10:25 PM
Nmbr1GMfan's Avatar
Powdercoating will transfer heat out of piping faster than an exhaust coating. but chances are your coater would coat over the previous coating unless it is chiping or flaking.
Old May 8, 2007 | 10:57 PM
trtturbo's Avatar
the coating on the pipe is an HPC coating that is made to dissapate heat. It does work well too. It is not a typical ceramic coating.
Old May 9, 2007 | 10:20 AM
GR33N GoblinM6's Avatar
Are you talking about the Black powdercoating? Because HPC offers a black ceramic coating that is rated to 2000*F.. looks awesome. I have been down to HPC to help a friend pick up some manifolds that had this coating.
Old May 9, 2007 | 01:54 PM
rahmnja's Avatar
Yes...
I already have the exhaust wrap for the hot side (black) but Im wanting to change the color of the pipes running from the turbo to the TB. I figured you would want that side to dissipate as much heat as possible.,
trtturbo do you know which of the ceramic coatings of HPC it is?
