how much hp can a stock ls1 take?
#43
11 Second Truck Club
How much PSI is safe on stock compression? I have a Turbo that I salvaged off of a SISU with very low hours on it. I would like to use on a Silverado. What are the upper limits of PSI I can boost a stocker.
#45
8 sec potential, 12 sec slip
Doesn't matter so much as to how much boost, what really matters is HP, and the limit is around 500rwhp in most cases...
#47
Right? So your saying that if it takes 20 psi to make 500 hp thats ok as long as it's under 500 huh?
#48
try taking that number down to about half that.
unless you're putting 400* air into the LS1, its going to be making 500hp long before it reaches 20PSI..
#50
Originally Posted by ChevyChad
Mine was very close to 500rwhp (489) with only 6~7#
thats because 1 . you have a big motor 2. you have a big turbo
20 psi of boost out of a t28 does not = 20 psi of boost out of a T04E 60-1 or T67 r T70 etcc
#51
we saw a c5 auto, single t make 578hp on a bone stock motor .for two years..and never blew up...and he tryed after he orderd a new 408...gymtitan's car..alot becaues it was tuned right! or was it? hummmmm..could be just lucky...yeah thats it ....LUCK..
#52
do not turbo, or supercharge a stock motor, thats an accident waiting to happen, its too much stress on the bottom end of the motor, u might want to get heads and a Camshaft from MTI first. go to www.motorsporttech.com
#53
scared of boost are we?
#55
#56
Originally Posted by THEhomelessONE
when i say that i mean reliably, dont know much about american engines, thanks, i have 2500 to get a cheap turbo kit off ebay or i can get 5500 by augast?
5500 would easily do it for a used kit. but be ready for bs things and little odds and ends.
do it the first time and do it right, you won't have problems out of it.
get sloppy with Forced Induction and you lose things...
#57
id rather just wait until september or october to get 9 or 10 gs, then ill do it the right way, i dont want to have to fix it every weekend, then my dad will be saying " see i told you not to get a domestic car! " lol
#58
#59
