How Can I Make This Inlet Pipe?
Old May 11, 2007 | 10:09 AM
JasonWW's Avatar
Default How Can I Make This Inlet Pipe?
Hey guys, this is not on a turbo car, but I think this group probably has the most knowledge to answer this question. I want to build a simple inlet tube from the throttle body and have it come forward and then angle down. Something similar to this picture:
Now I don't want to get rid of the factory latch so I want the tubing to turn down sooner. I was thinking that the radiator could be leaned back a little, but I don't think there would be enough room. The other thought was to cut a whole in the radiator cross member and run the pipe through it. Is that the best way or is there another way?
Old May 11, 2007 | 10:11 AM
Boostaholic's Avatar
what are you trying to do? make a CAI? There is a lot of hot air passing through that radiator.
Old May 11, 2007 | 10:13 AM
JasonWW's Avatar
Yes, that is basically it. I want to relocate the MAF as well.
I know the air on the back side of the rad is hot, that's why I want the tube to go in front of it to get the cool air.
Old May 11, 2007 | 10:32 AM
venom346's Avatar
Mines similar, what I did was cut a small portion out of the backside of the radiator support, removed the AC condensor and used 2 1/2 pipe. Barely fits but it works.
Old May 11, 2007 | 10:45 AM
JasonWW's Avatar
Did you put the condensor back or do you not have AC? Do you have any pics?
I would love to get my hands on one of these Incon parts, but they are extremely scarce. Even though I would have to combine the lower parts in order to have the MAF fit it, the extra work would be worth the cool looks.
I may be able to lean the rad back just a little and then cut away maybe the back half of the rad cross member. Just take a hole saw to it and then weld in a half circular piece to give it strength. Or else I could cut a hole right through the middle and slip a circular sleeve in and weld it up to return the strength.
Old May 11, 2007 | 11:17 AM
JasonWW's Avatar
On the other hand, why not go for broke and cut a 4" hole through the middle of it and leave the rad in place? Then run a 3.5", or whatever size the TB is, tube right through it.
I could then get a polished LT1 style rad cover for it and cut a hole through it as well. Would that work or am I going to cause problems elsewhere?
Old May 11, 2007 | 12:01 PM
MIGHTYMOUSE's Avatar
mine goes where the factory a/c condenser used to live, but all other things, hood latch, and radiator support are unmodified.
Old May 11, 2007 | 12:26 PM
JasonWW's Avatar
I'm keeping my AC so I can't remove the condensor.
I notice you guys run fairly small diameter tubing, is that because of the boost on it? I think with a non-boosted car I may have to run a larger diameter and I just don't see any way to fit it without cutting my way through.
I could cut a hole like this and then reinforce it. I could also run some tubing under that front lip and weld it in for more strengh.
Or I could slice a whole section out of the middle and weld in plates on either side and then connect the 2 sides with tubing giving me enough room to run the intake tubing through.
Old May 11, 2007 | 01:36 PM
if you really want to get into all that i guess it would be different.
my 3" tubing is roughly the same dia as the factory tb exit where all of the air has to go.
keep in mind if you have a/c there really isnt much room on the other side for a filter set up either.
Old May 11, 2007 | 01:42 PM
JasonWW's Avatar
I'm converting it to a front breather so there should be plenty of room for a filter.
I think I have a pretty good idea of the best way to do it. I'll cut a hole a little bigger than I need and then make a ring to slip inside it and weld it all in. I can also add a piece of tubing across the front for more strength. The shroud that holds the radiator will cover any uglyness.
Old May 11, 2007 | 02:40 PM
ddnspider's Avatar
im sorry but i have to ask why?your car isnt an NA dedicated max effort racecar.why dont you just do a ram air lower airbox with a lid and smooth bellow and call it a day.no reason to hack up the front of the car and moving stuff around for such a minimal gain.
Old May 11, 2007 | 02:46 PM
JasonWW's Avatar
Please, please please, don't ask me for reasons. This is what I want, so I'm going to build it. Thank you.
Old May 11, 2007 | 03:36 PM
ddnspider's Avatar
okie dok.good luck with it.
Old May 11, 2007 | 09:05 PM
BigJls1's Avatar
Dude,
Did your dad tell you this when you were a kid, let the man be creative. I'm Willing to bet that this type of mentality is were SLP, lengfelter and others started. I think this is an awesome idea. You know what , I started a thread a while ago about twin turbo rear mount. Many badmouthed "why" just buy an sts blah blah...........You said it best if you have to ask why they dont understand. not everybody excepts "The Norm" or "whats out there".
Press on dude. The pipe idea will work just use a thick like .250 wall or better. we do this type of proceder all the time at work. I think this will be awesome and if I wernt goin twin rear mount then I would probally hijack this Idea- (still might) . GO FOR IT.
Old May 11, 2007 | 09:27 PM
ddnspider's Avatar
Originally Posted by BigJls1
Dude,
oh give me a break captain keyboard commando,its not even remotely in the same group as twin rearmounts or stuff that companies have came up with like way back when Harlan said he wanted to turbo his Fbody type stuff.this isnt an original idea and it wont be a revelation to NA power of Fbodys thats why i asked.if he can post a question i can ask a question.the only stupid question is the one never asked.i personally like his car and this wheel swap he did,i just wanted to know his reasoning on doing what hes planning on doing so you have a nice day.
Old May 11, 2007 | 09:48 PM
BigJls1's Avatar
point taken,
I thought you were tring to be negitive. I was not comparing this to rear mounts (a twin rear mounted fbody is not a new idea, I just want input and got negitive bs) but the compaison to others in this community that dont like to get outside of OEM. I guess I took your question wrong, sorry.
Ping King's Avatar
this person asked a question of how, not why.
Old May 11, 2007 | 10:18 PM
ddnspider's Avatar
point taken,
no worries....Jammer on here did a badass twin rearmount setup.who knows maybe there will be perks to a setup idea like this.anyways,no more hijacking im out.
Old May 12, 2007 | 12:15 AM
JasonWW's Avatar
As far as why, let's just say I'm not a fan of cookie cutter cars.
When you put a lot of effort into something, it shows. Those are the kind of cars I want to see. I just ran across some of the cars that Stenod built. Now these guys think like me. They are not afraid to get their hands dirty and do some real modifications. The effort shows.
http://www.stenodperformance.com/gal...s.php?album=30
