Car back fires while Entering boost
Old May 15, 2007 | 07:01 PM
Eatinstang4life's Avatar
Well just got back from tuner shop, We are stumped, we are begining to think it may be a broken valve, or bad coils, we eliminated it being wires or plugs, the 02s are reading fine, no codes are being thrown no lights coming on. I am stumped, I am going to do a compression test tomorrow to make sure everything is ok in that department.
Old May 15, 2007 | 07:07 PM
Old May 16, 2007 | 07:06 AM
aby one think its the valve spring
Old May 16, 2007 | 07:13 PM
any other info guys still doing it, I am going to do a compression test tonight just to see if everything is ok
Old May 17, 2007 | 09:44 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You could be floating valves.
Can you hold the car in 2nd gear and gradually wind out the gear to 6200? What happens? Does it start to miss?
Old May 17, 2007 | 09:58 AM
yea if I gradually get on it it WILL NOT MISS OR BACKFIRE, only when I like floor it is when it does it bad.
Old May 17, 2007 | 11:40 AM
last night I checked all the ground wires and such. Do you think it would be a good idea to unplug 1 injector wire at a time and drive to try to limit it down to one cylinder?
Old May 17, 2007 | 12:14 PM
LS1Tech Co-Founder
If you can wind out a gear to your rev limiter, and the car is not missing, then the problem is probably not the actual fuel system right?
Here is what my checklist would be and why:
Fuel pressure: at WOT if it drops more than 10psi it's problematic. Stock FP is like 57psi or something.
Plugs: Too wide a gap, and you will lose spark at WOT. The spark won't survive as it tries to jump the gap.
Valvefloat: Not enough spring pressure will result in your valves not opening and closing properly.
Tuning: If your tune is too rich, the car will run bad.
Grounds, Electrical: Can result in the pcm not having enough power to run, and the car can shut off maybe cut out. This can be pretty rare.
Bad 02's: Fouled out or dead 02's won't switch, and then you will default to running rich.
Old May 17, 2007 | 12:32 PM
Thanks john thats great info
I checked the fuel pressure its great its not dropping but about 3psi under load still about 63psi under load
I have the plugs about .32 now I will gap them to .28 see how that does.
I don't know how to check the springs other than just replacing them
The tune looks good.
02s are about year old, but they could still be bad I guess
Old May 17, 2007 | 07:16 PM
LS1Tech Co-Founder
What valvesprings are you running?
Old May 17, 2007 | 07:50 PM
stock
Old May 17, 2007 | 08:57 PM
  #32
Torchvette10's Avatar
Hi there,
please look at this thread and watch video number 3!
http://forums.corvetteforum.com/show....php?t=1699040
I think I have a similar if not the same issue as you. Look at all the parts I already changed and stuff I tested. I still have the issue, I am starting to hate my car!
Keep us posted on what you find out!
Old May 18, 2007 | 08:18 AM
  #33
Anything new?
Old May 18, 2007 | 09:01 AM
  #34
LS1Tech Co-Founder
Seems like you should run CC0918's or Z06 springs at least for your power level. I'll go with valve float for now. Stock springs will float with the stock cam at 6300...
Old May 18, 2007 | 09:10 AM
  #35
Devil's Due's Avatar
I agree that 918 or the equivilant are needed. I had float on my stock springs after I put my turbo on.
Old May 18, 2007 | 09:31 AM
  #36
I know I will need to upgrade my springs but It is backfireing way before 6300 rpm.
Old May 18, 2007 | 10:01 AM
  #37
LS1Tech Co-Founder
You need to run more spring anyway, but I'm pretty sure that's your problem. As soon as you get into big boost the valves float. If it was me I'd run 918's, but perhaps other folks might like the Z06 springs.
Old May 18, 2007 | 10:11 AM
  #38
OK sweet man Thanks a lot for all your help. I will swap out and upgrade to the 918's
Old May 19, 2007 | 04:32 PM
  #39
just found out it only does it when its cold a few minutes after start up, if I wait til opt temp it does not do it.
Old May 19, 2007 | 05:52 PM
  #40
JAvenger007's Avatar
who did your tune? and how many miles on stock springs (the car)?
Most float cases ive seen have been 7+ psi. But its not unusual for 400+ cars
