Going to try a little camshaft experiment..
Old May 18, 2007 | 10:25 PM
70Stang's Avatar
Old May 19, 2007 | 12:26 AM
kp's Avatar
kp
Only was able to make one pass today, didnt hook at all and ran a 9.45 @146 with a 1.46 60 foot. Oddly enough my boost really hasnt changed. Hopefully I'll be able to make a couple clean passes tomorrow. Took me a little while to get the car to idle right.
I'm beat and going to bed.
Old May 19, 2007 | 04:24 AM
EPP's Avatar
EPP
Good luck today, Kevin. We're anxiously awaiting the results! Bob
Old May 19, 2007 | 08:36 AM
Rickys S/C Z28's Avatar
yep anxiously awaiting the results !!!!!!!!!
Old May 19, 2007 | 09:35 AM
Bad30th's Avatar
Yeah, I was gonna ask if you were gonna change the tuning at all.
Thanks for the info, looking forward to hearing more as I'm still running the LS6 cam you had such good results with.
Rob (Bad30th)
Old May 19, 2007 | 10:08 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'll be interested to see what it does. I think the small cam in FI is a myth. Just look at what the big guns are running and you'll see a trend. Yeah the small cams may work well, but just as in most instances bigger is better. Granted there is a bondary.
Old May 19, 2007 | 10:57 AM
T/A KID's Avatar
I would rather see that 222/228 on a smaller LSA like 110 instead of a 115???
I have seen Blower cars with Tight LSA's haul ***, lol.
Thats another MYTH.
Old May 19, 2007 | 03:26 PM
SSmokin 01's Avatar
Subscribing .
Old May 19, 2007 | 06:11 PM
6techniques's Avatar
Im def waiting to hear more on this one, good luck man!
Old May 19, 2007 | 08:55 PM
EPP's Avatar
EPP
Any updates? Bob
Old May 19, 2007 | 09:21 PM
Inspector12's Avatar
TT-TECH Veteran
Thats another MYTH.
On a FI car I would have no less than a LSA of a 113 for a FI car, but not to say you would make power, but you would be pushing a lot of the air and fuel out the exhaust.
Old May 19, 2007 | 09:53 PM
  #32
Phil99vette's Avatar
7 Second Club
This is an interesting test and really want to see the outcome. I had one of the baddest dudes in the FI game design my cam and let me tell you, it ain't small.
Phil
Old May 19, 2007 | 09:57 PM
  #33
Tiago's Avatar
Phil
what LSA is it?
Old May 19, 2007 | 10:09 PM
  #34
Z8'S's Avatar
Phil
Me Too
Old May 19, 2007 | 11:23 PM
  #35
kp's Avatar
kp
Rob (Bad30th)
I havent touched the WOT tuning, the BS3 was on auto pilot for both. I fooled with the timing a little today and didnt really change anything but I was on DOT 11.5x28 QTPs that are like 1" shorten then the 10.5x28 ET drags I usually run. Cant complain about a 9.32@146 on those tires with a D1SC @ 14.5psi.
Anyhow, after 6 passes I will say that the top end has improved but until I get on some better tires I would say the 60 foots have dropped off a little. Car is running 145-146mph in 2200' DA which is pretty darn good. I'll have some vids tommorow, I lost first round against a 8.30 turbo SBC 4th gen firebird. Another car in the class was runing 7.90s so I knew I wasnt going to go far but the Year One Experience is always a fun race.
As far as myths I subscribe to the wide LSA for centrifugal superchargers. I'll trade off the dyno friendly peak power of lower LSA cams for a more spread out power wide LSA cam. Not to mention the increased drivability and idle quality.
Boost really hasnt dropped much, about .5 PSI which kinda surprised me some. The main reason I bought this cam was to use in a bigger engine, figured I would try it out on the 346 for the heck of it. With 9.2:1 compression and installed straight up it has a pretty good lope, the 222/228 sounded almost stock, this sounds like it has a cam
I'll leave it in for a while, it no doubt pulls harder up top but untill I try it with some better tires I wont know about the 60 foot. Videos tommorow.
Old May 20, 2007 | 03:58 AM
  #36
great man cant wait , also is this EPP custom grind that has the big lope?? i think he used it on an STS car??
Old May 20, 2007 | 05:00 AM
  #37
EPP's Avatar
EPP
Smile
Yes it is the cam you are referring to, which is this one. http://www.exoticperformanceplus.com....html?item=679
Bob
Old May 20, 2007 | 05:06 AM
  #38
EPP's Avatar
EPP
Smile
I'm glad to see the cam is working in the 346 for you, Kevin. It will indeed be interesting to see what it does on the ET Drags you normally use. Bob
Old May 20, 2007 | 05:19 AM
  #39
Bob
just checking !!!!!!!!!!!!! this WILL be the cam i buy i love the way it sounds!!!!!!!! please keep us updated on it KP!!!!!!!
Old May 20, 2007 | 07:12 AM
  #40
7 Second Club
Originally Posted by Tiago
what LSA is it?
I'm not 100% sure but the duration is around 260 and LSA is around 115.
