:( sts.....car is shaking and stumbling
Old May 22, 2007 | 04:49 PM
quik01ss's Avatar
Unhappy :( sts.....car is shaking and stumbling
had the car with the sts kit only 5 psi car was runing fine on the highway but got in town and starting off its stumbling and trying to stall....got it home made sure all wire were on they were car was still doing the same....now changed the plugs still changed to the old wires still the same....i dont know what to do....on the high way coming home ses light flashing pulled over shut it off...turned it on light is gone got home ses light on after changing plugs ses light went off and still runnin light crap
Old May 22, 2007 | 04:57 PM
pdanrichey's Avatar
Run the codes. Flashing SES means danger to manifold, but typically, you can just tell it to shut up and continue with your 5th stage of NAWS. j/k.
It's misfiring for sure then. If you changed the plugs and wires, it's probably a fueling issue. Crappy fuel filter or fuel pressure regulator could cause that. When you pulled the first plugs, what did they look like?
How about some different punctuation than just "..." next time??
Old May 22, 2007 | 05:05 PM
quik01ss's Avatar
first plugs i looked at i tryied to get a pic but u cant see it but normal wear but i started the car and the ses light was flashing meaning misfiring...fuel pressure is good i put my gauges on it im at 50 to 51 psi brand new fuel filter also..... :''(
Old May 22, 2007 | 05:13 PM
smoke20's Avatar
did you check to see if you had oil on the MAF??? - it will mess with the readings and cause all kinds of trouble.
Old May 22, 2007 | 05:43 PM
quik01ss's Avatar
no oil on maf im gona get the code that its throwing
Old May 22, 2007 | 06:19 PM
quik01ss's Avatar
found it guys thanks for the help......intank fuel pump blew a hose but again thanks guys
Old May 22, 2007 | 09:27 PM
JAvenger007's Avatar
Your intank fuel pump blew a hose? where was the fuel goin?
Old May 23, 2007 | 10:54 AM
black98ws6ta's Avatar
Ls1 fuel pressure typically is around 58. When it blew it was probably enough to supply the motor with enough fuel to run but not enough pressure to run correctly.
Old May 23, 2007 | 11:00 AM
Eatinstang4life's Avatar
your car would not run at all if it was not getting any fuel at all, I am confused.
Old May 23, 2007 | 11:20 AM
ddnspider's Avatar
my car did that on my twin intanks....so fuel went up the 1 pump and leaking out the hose for the other pump so it would sorta run but not really
Old May 23, 2007 | 11:29 AM
yea i could see that happening
