boost controller
Old May 23, 2007 | 09:58 AM
SS101's Avatar
Default boost controller
search came up empty, what do you guys know about a good electronic boost controller?? something that would work with the new APS f-body kit and give me between 5psi and 15psi
Old May 23, 2007 | 10:03 AM
pdanrichey's Avatar
I have a STS electronic with a manual **** controller for sale (used). Should work with any setup I would imagine.
Old May 23, 2007 | 10:09 AM
Ryan K's Avatar
Pathological Modifier
Eboost 2 or Exhile MSBC-1, only way to fly for electronic boost controllers.
Old May 23, 2007 | 10:10 AM
Inspector12's Avatar
TT-TECH Veteran
I love my Eboost 2 after I figured it out.
Old May 23, 2007 | 10:53 AM
DrTurbo's Avatar
LS1TECH Sponsor
E-boost 2 F.T.W!!. We use them on tons of our customers cars.....works awesome.
Old May 23, 2007 | 12:14 PM
Sweet71's Avatar
Aem True boost. Guage and boost controller awesome set up!!
http://www.aempower.com/ViewCategory.aspx?CategoryID=68
Old May 23, 2007 | 10:55 PM
Brabus2's Avatar
Blitz SBC I color on my C6 APS TT.
Old May 23, 2007 | 11:08 PM
4SFEDZ's Avatar
How Does One Work? Dont You Have To Change The Tune?
Old May 24, 2007 | 12:10 AM
obZidian's Avatar
right, i like the eboost2...
however, the new blitz sequential boost controller is a nice piece. Has a dual soleniod setup where one is the main and the other supportes it for fine boost control. You can store four boost presets or more, and setup your boost level per gear. It's designed to maxmize your boost pressure so that you gain the most you can from every psi you add or sustain.
The colored unit is up there in price, however, the smaller, non-lcd dual is about 399.99
I think the colored is msrp'd around 600-700.00
imo, it worth looking into..
dont do a manual, it will only bring you gief and no sleep at night, trust me, i know. They can be maded to work but it is really not worth it when there are el. controllers that hold your boost more efficiently.
Old May 24, 2007 | 08:22 AM
silverbullet02's Avatar
T is for Towing not Turbo
Another vote for E-boost2...had mine on for a month now and after a few tries and lotsa reading, got it figured out pretty quickly, and it's easy to use and it works absolutely phenomenal. I'm lovin it...
Old May 24, 2007 | 09:23 AM
KWIKKAR's Avatar
which Eboost 2 did you guys buy. They go up to 40- 60 PSI and there like $650+ Dont need that much. Help!
Old May 24, 2007 | 10:17 AM
http://www.forcedinductions.com/electronics.htm
I've got the 0-40 cause, well, yeah...
Old May 24, 2007 | 07:55 PM
52172's Avatar
AEM Tru-boost. got it for like 275 dollars and simple very easy to use. Not nearly the features of the E-boost2, but allows you to control the boost from inside the cab and is also a boost gage. :
Old May 24, 2007 | 08:24 PM
VINCE's Avatar
Shorty Director
Blitz SBC-ID here..
Old May 25, 2007 | 08:32 PM
parish8's Avatar
single digit dreamer
i have the Blitz SBC-ID on my truck. it is a very nice unit. easy to use and speed based boost control. cost lots of $$$$ though.
on the fairmont project we are using the megasquirt to control the boost. right now there is no speed based control but there is rpm and tps based charts. the squirt is just geting to be a better and better deal. it cost $40 for the parts to make the boost controler work and a little soldering. with the smallest spring in a tial 44mm we had control from 5psi up to 18psi. we steped up a couple of steps in springs and now have control from 9psi up to at least 21psi(80% duty cycle).
By Brett Foote | 2026-06-04 05:00:17
