427ci trubo cam??
Old May 25, 2007 | 10:12 PM
SS101's Avatar
Default 427ci trubo cam??
search won't cooperate...are there any good 427 turbo cams out there or will i have to go custom???
15psi - DD/road racer so it needs to be a pretty streetable cam. one guy already suggested the ls7 cam, i'm inclined to agree unless anyone know of anything better.
thanx
Old May 25, 2007 | 10:48 PM
qqwqeqwrqwqtq's Avatar
A little more information would be helpful
Old May 26, 2007 | 10:20 AM
SS101's Avatar
well i'm planning on using the APS twin turbo system, 4.125" darton sleeves and a lunati 427 rotating assembly (10.6:1 cr), ARF mongoose heads (72cc combustion chamber, 225cc version), cam undecided obviously, valve train also undecided (can't do all that until you pick the cam right), fast 90/90, all the other bolt ons except exhaust - the APS system takes care of the manifolds back to the cats more or less and i'll drop in a three inch exhaust from the cats back with twin cutsouts.
if you want more specifics i'll be happy to oblige
