Who's making the most power from a 347?
Old May 29, 2007 | 10:37 PM
Lythropus's Avatar
Default Who's making the most power from a 347?
I'm wondering what the highest output forced induction 347 is on this site...
Dyno Queens and track times with close to stock cubes, 346's and 347's only, no 360 or 370+ engines...
Old May 29, 2007 | 10:56 PM
Navy David SS's Avatar
I believe that Harlan with his turbo set the standard high with his 347 set-up. If I'm not mistaken: 8.21 in th 1/4 - done a couple years ago. Use the search and you'll find some write up on it.
David
Old May 30, 2007 | 12:20 AM
rufretic's Avatar
Subscribing, I'm interested to see what people have done with the 346. I get finished with my tune next thursday and will take it to the track soon after. I'm pretty sure my setup will be pushing the limits of the stock 346.
Old May 30, 2007 | 01:04 AM
y2khawk's Avatar
Best MPH was 172'ish, at 3250 lbs. Something in the 1100 RWHP range i'd guess.
Damn that was a long time ago
Old May 30, 2007 | 08:15 AM
Speed's Avatar
This is a blast from the past but didn't Rob Raymer(sp) claim something north of 800 to the tires on a stock bottom end? Never followed it that closely tho...
Old May 30, 2007 | 08:53 AM
CHRISPY's Avatar
Arun just did 920RWHP with a 347 and ATI F1 through an auto
Old May 30, 2007 | 08:58 AM
camaroextra's Avatar
I was reading that, thats crazy! Isnt it through an ls6 manifold too?
Old May 30, 2007 | 11:37 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Yeah Matt made huge numbers.
Arun would be the big dog right now, but my car has made 867rwhp with my single 88 thru a T400 trans.
Old May 30, 2007 | 03:13 PM
99Z28LS1's Avatar
just needs a little more fuel and he said it could go further right?
Old May 30, 2007 | 03:48 PM
SSilverSSurfer's Avatar
Tiago did right at 1000hp with stock cube twin turbo. his car was impressive now hes getting down with the real stuff
Old May 30, 2007 | 03:50 PM
rufretic's Avatar
That must be a very well built 347. I wish I had the money to upgrade my 346 so I could try pushing a little harder.
Old May 30, 2007 | 03:55 PM
rufretic's Avatar
That's with built internals though, right? If people are putting down this much power with stock blocks why does everyone say 500rwhp is the limit?
Old May 30, 2007 | 04:10 PM
yeah, i guess i worded it wrong. but you can go a long way with a 346-7. obviously harlan proved that as well as tiago
Old May 30, 2007 | 04:46 PM
Mr_president's Avatar
well since i have been in the crash im thinking of what i can do next when i recieve some cash. I think im going to stay with a 346. not to sure but what forged parts would i need to push 800 to 900 to the tires. also what does the stock crank handle i herd it was about 800
Old May 30, 2007 | 05:55 PM
i believe Kyle(NastyTa) is on stock crank and hes doing over 800 to the tires
Old May 30, 2007 | 06:03 PM
Got Me SOM's Avatar
you should come out of retirement.
Old May 30, 2007 | 07:56 PM
Lythropus's Avatar
This was when you had incon's? more details please...
Pistons, rings, rods, intake, transmission and rear gears...how much boost?
Old May 30, 2007 | 08:20 PM
Cam72aro's Avatar
Tiago had a stock crank with good rods and pistons.
Old May 31, 2007 | 01:15 AM
y2khawk's Avatar
mine was on a stock crank, block, and caps.
shitty 317 heads, GMPP carb manifold and the old twin 66 setup. Glide for the trans, 28x10.5W tire, and 3.60 rear gear.
Nothing specially really.
Boost = all the 66's would make about 30 peak, dropping to 27 ish by 8k RPM.
Old May 31, 2007 | 02:51 AM
99Z28LS1's Avatar
i think people misunderstand between the blocks or the bottom end
