Starting installing STS rear mount kit
Old Jun 2, 2007 | 10:28 AM
JAvenger007's Avatar
500rwhp? what kind of turbo again? Youll need to run at least 7-8psi to get close. Do you have a FMIC?
Old Jun 5, 2007 | 01:21 PM
Cchris1109's Avatar
i have heads/cam already.
New plan though, i am putting in new heads and a new cam.
Just purchased 6.0L heads and a Z06 cam.
got the exhaust welded up so basically im running without mufflers and it sounds like ****...
Old Jun 5, 2007 | 01:34 PM
NicD's Avatar
7 Second Club
That's what I would have done for a good, simple, and efficient build.
Old Jun 5, 2007 | 01:54 PM
I kinda liked it when I ran no muffler before the STS. Nothing spectacular but not gross like I expected.
Old Jun 5, 2007 | 04:34 PM
jeffboy757's Avatar
haha im picking up my car tomarow, i was looking at it today and all they have done so far is hacked off the muffler.. dunno why its taking 3 days but whatever. the drive home will be with no muffler
Old Jun 5, 2007 | 04:58 PM
no problem with that. I went a whole year with no muffler. gas mileage went down a little though. I averaged 26 with A/C on the highway instead of 28-29 with catback/lid
Old Jun 5, 2007 | 05:28 PM
koolaid_kid's Avatar
Originally Posted by RooRnZ28
yes, if you think about it, it does ACT like a sfc, but in no way is it a replacement for an actual solid sfc piece. they keyword here is ACT
Now c'mon, guys. Just take that piece of pipe, put one end in a vice, and try to bend it. Then do the same for the SFC. Exactly the same, right? After all, STS would not lie to you just to sell their product.
Old Jun 5, 2007 | 06:48 PM
smoke20's Avatar
those type of forces are not put on the pipe or sub frame connector ,, try installing in two vices then try to bend it with flex only === good luck
 Michael S. Palmer
Old Jun 6, 2007 | 11:58 PM
Cchris1109's Avatar
yeah i hope you can tune it
haha
Old Jun 9, 2007 | 05:15 PM
GhoSStrider's Avatar
It's a good thing you decided to change your set up. The heads and cam you had before weren't ideal for your set up. I believe those 5.3l heads actually raise your compression a little while the 6.0l lower it. Your new combo should work out better for you in reaching those numbers you want. Keep us posted.
