Starting installing STS rear mount kit
Old May 30, 2007 | 04:41 AM
Cchris1109's Avatar
Default Starting installing STS rear mount kit
just started the install
i am unsure on how the turbo will react to the Torquer V2 and the 5.3L heads.
But i ran most of the piping through and will be having a muffler shop weld the flange on and run open exhaust today.
Just need to run the wires to the oil pump, run the pcv check valve and the high/low switch.
Old May 30, 2007 | 11:55 AM
JAvenger007's Avatar
what size turbo? keeping the stock STS PCV setup?
Old May 30, 2007 | 12:25 PM
pdanrichey's Avatar
What are the specs on the cam?
The 5.3L heads...did you install that to up or lower your CR? I know the 6.0L truck heads are a great swap for FI setups b/c it lowers your CR to a more boost friendly spot. (plus they're CHEAP!!)
The heads obviously are going to affect how much boost you can run. C5 Z06's, which have a higher CR than the LS1's are running 5.5 - 6psi through an FMIC on a conservative tune and making 500+rwhp. On the LS1's, you need about 8psi to get those numbers if you have stock heads/bottom-end.
Old May 30, 2007 | 12:57 PM
RooRnZ28's Avatar
good luck.... any problems come up, we're here if you need us!!
Old May 30, 2007 | 03:10 PM
99Z28LS1's Avatar
500rwhp can be achieved with the right tune on an LS1....... im one of the lucky ones and she has a little more left in her (TRT says). its possible, just gotta choose the right combo. i imagine if you built an LS1 with 6L heads and the right cam, it could be possible to achieve 550rwhp..... im only on 5.5-6 psi and im just over 500, imagine where i could be with 7.5psi AND 6L heads...... gotta be careful on the cam selection.
GOODLUCK with the build and keep posting threads to keep us updated
Old May 30, 2007 | 04:40 PM
Cchris1109's Avatar
its a 232/234 .595/.598 @ 113 lsa
im in positive overlap but its only 7 degrees so im running only 5.5 psi.
the heads/cam were done already but i may swap out with a 6L head if tuning becomes aproblem
Old May 30, 2007 | 04:41 PM
Cchris1109's Avatar
one question: how tight do i torque the driver side k member bolt.
because now that one pipe is making it stick out a little more
Old May 30, 2007 | 07:14 PM
Cchris1109's Avatar
hit my first problem
i have subframe connectors and its blocking the way dammit!
Old May 30, 2007 | 11:10 PM
jeffboy757's Avatar
hahah i have the same problem. thats why i didnt bother with the piping that came with the kit. i just ordered a 180 bend, 90s,45s, and straits today. well see how hard it is to do all my own piping
Old May 31, 2007 | 02:56 AM
99Z28LS1's Avatar
you poeple that do DIY will save tons of money, i wish i was braver before i bought my kit.
goodluck
Old May 31, 2007 | 09:44 AM
smoke20's Avatar
goodluck
they save money but waste alot of time.. just remove the lt side subframe connector, your charge pipe fits in same location and acts as a subframe connector, problem solved
Old May 31, 2007 | 10:16 AM
pdanrichey's Avatar
For any DIY guys, I do have the non-convertible pipe # 4 for the STS kit ready to be shipped out!! It's the looonnnngggg pipe that runs up the driver's side. I need to sell it!!!!
Old May 31, 2007 | 11:12 AM
ZL1Killa's Avatar
check my signature link to my build
Old May 31, 2007 | 03:31 PM
GTObsessor's Avatar
Yah the piping is supposed to "act" as a SFC for that side of the car... if you read up on their website it tells you that. Kinda dumb IMO lol
Old May 31, 2007 | 04:40 PM
pdanrichey's Avatar
My car already has SFC's However, I lack a solid roof over my head
Old May 31, 2007 | 11:06 PM
Cchris1109's Avatar
i dont see how hollow aluminum piping will act as a subframe haha
Old Jun 1, 2007 | 01:41 AM
jeffboy757's Avatar
hahahh yea stop and think for one second, a hollow peice of crap 1 pound aluminum pipe. or these suckers welded in.
Old Jun 1, 2007 | 07:02 AM
smoke20's Avatar
well it is a hollow pipe with flat solid mount tabs on each end for installation, it is a very ridged piece and wont flex, a round tubing is harder to bend. trust me i have it installed on my car it is very solid. and with the rt side subframe welded it stiffens the car very nicely.
Old Jun 1, 2007 | 12:32 PM
RooRnZ28's Avatar
yes, if you think about it, it does ACT like a sfc, but in no way is it a replacement for an actual solid sfc piece. they keyword here is ACT
Old Jun 1, 2007 | 09:22 PM
Cchris1109's Avatar
well i chopped off my SFC and installed that pipe
now all the pipes are installed, tomorrow i will be running oil lines, power line, and wiring harness
then monday i will have a custom Y pipe made with 3 inch exhaust to the T4 flange....
tuesday-wednesday will be installing the 42 lbs injectors and finally connecting the turbo to the exhaust.
i will then do a basic tune and then dyno tune and hope for great results. im hoping for 500 whp...one can hope.
