cam effects on turbo spool?
Old Jun 1, 2007 | 12:01 PM
98redorangeta's Avatar
Default cam effects on turbo spool?
I am looking for some thoughts on the effcts of cam selection and turbo spool my thinking would be that lower lsa with more exhaust duration would be better for spool is this correct or am i missing something?
Old Jun 1, 2007 | 01:32 PM
99Z28LS1's Avatar
im not a genius when it comes to spool or cam selection, but it was told to me that LSA has a lot to do with it....... my LSA is 115, compared to a lot of people's 112-114....... i'd have to drive another STS car with the same **** to really tell you if there's a difference
Old Jun 1, 2007 | 01:52 PM
mdhmi's Avatar
Very good question.
I've run a Lingenfelter GT2-3 and a custom reverse split turbo cam on my TTi setup, and what I notice the most able the larger custom cam is carries power much higher in the power band.
As for spool - it's really hard for me to say as I switched from a manual transmission to an automatic so the spool is near instant now.
Old Jun 2, 2007 | 12:18 PM
2000 Tran Zam's Avatar
I would assume that if you have a higher LSA/low amounts of overlap... it would spool faster cause instead of bleeding the pressure out its ran through the exhuast to spin faster... that would be my guess.
Old Jun 2, 2007 | 02:40 PM
99Z28LS1's Avatar
thats what i thought too, i have a 228/228 .588 .588 on a 115 and its nice with a 6speed. and i have a rear mount too
Old Sep 10, 2012 | 10:59 AM
JoshuaGrooms83's Avatar
how has this cam held up over the years? been lokking over differnct cams and was curious about peoples results with these and rear mount turbos
Old Sep 10, 2012 | 11:17 AM
TurboMark8's Avatar
Advancing the cam will help a bunch in spool-up as it will move your powerband lower in the rpm range, producing more exhaust flow sooner. I've jad to advance some cams (on non-lsx apps) up to 6* in order to get turbos with massive exhaust housings to spool on the street
viseversa, I've retarded cams to get smaller turbos to spool later in order to reduce stress on the rotating assembly (factory bottom ends)
Old Sep 10, 2012 | 01:47 PM
TurboS10's Avatar
Best thing to do is find a calculator for dcr that shows you what the valve events are when you move things around.
Advancing the cam does- move intake and exhaust opening sooner. EO sooner as stated hotter gas hitting the turbine. Intake sooner = higher cyl press since the IC is sooner trapping more volume.
widen the lsa does - IO later and EO sooner.
IO later = more rev, less reversion
more to it, but lunch is over.
