What are your thoughts on Boost regulated cut outs?
If a cutout is what you want (I prefer a free flowing but quiet exhaust all the time) get one of the electric ones. I would recommend getting the car tuned with them both open and closed so as to make sure its safe.
My car was tuned with the cutouts uncapped, it may run a little richer and not be an optimal tune w/ the cutouts closed, but then whats the difference?...it's not gonna run optimally with the cutouts closed anyways.
QTP:
http://shop.quicktimeperformance.com...ct_detail&p=27
DMH:
http://www.nonsponsorlink.com
I can't comment on the QTP but as I said earlier the DMH is know for the motor loosening up from time to time. They do offer a 4 year warrenty and are pretty good at honoring it but who wants to deal with shipping parts back and forth and having downtime? If you don't mind the getting under the car and uncapping it by hand the manual one will do the job and technically flow better as there is no butterfly and shaft in the flow path. You never have to worry about the manual one sticking either.
Hope that helps.
I set my DSM at 20 PSI with full exhaust, then when I changed gear oil I had to drop the back portion of the exhust leaving me with a short DP only. I dorve the car for a day just for fun and my max boost never went about the previous 20. It would spool quicker but never went past the preset limit. It did this with both a manual boost controler and a electric.
This spiking is not boost creep. Boost creep is when you increase in psi above the setpoint as you increase in rpm... (whether or not you have a restricive or free pst turbo exhaust). This shows as the volume of exhaust gass increase the wastegate isnt capable of bleeding it all off...
These two circumstances seem similar (oh, I am just speculating in my first paragraph on why I think the psi spikes up).
Like you stated creep and spiking are two different things. A spike can last for a quick second and then settles. The creep is basiclaly an uncontrolable building of boost.
If you are just on the WG spring itself with no boost controler then you shouldn't have this problem unless there is some restriction in the system.
If your car is tuned with the exhaust, THEN you open it up......hello more boost at all RPMS, and a serious lean issue.
So in general its better to tune for it open, and then you can always close it and run less boost...
Ya, next time round Im running a minimum of 91/101 mix all the time...
I finally dropped the car off at keiths last night, lol. Hes gonna try to pull the motor today, if not tuesday and let me know whats going on.
Hopefully its just one piston that needs to be replaced so I dont have to balance and blueprint everything again.
