turbonetics warranty
Old 06-10-2007, 07:08 PM
HUNTER02SS's Avatar
My whole system is vented to atmosphere. I put a big filter where my fillcap is and a small filter beside it on the valve cover.Seem's to be working fine.
Old 06-10-2007, 07:26 PM
52172's Avatar
Do you think we should vent like you before using restrictors on oil feed line? Do you think my factory PCV is the problem maybe? Thanks
Old 06-10-2007, 07:36 PM
HUNTER02SS's Avatar
I am not sure how your setup is.What work's for me might not work for you.But i know if you are building to much crankcase pressure by not having enough ventilation, then you can suck oil past your ring's and cause a smoke storm.If so that might make it seem like the turbo seal's are bad.I accidently plugged off my valvecover port's and it sucked oil into the turbo and it smoked real bad until i finally got it blowed out by driving down the road.
Old 06-10-2007, 07:48 PM
52172's Avatar
Thanks for your advice.
Old 06-11-2007, 11:11 AM
LS1TECH Sponsor
DrTurbo's Avatar
I think you spoke to Jose about this already. So goodluck...
Old 06-11-2007, 11:26 AM
52172's Avatar
I did thanks DrTurbo. We are gonna vent both sides and use an oil line restrictor no smaller than .050 and then as a last resort send in the TC76 for repair.
Old 06-15-2007, 10:24 AM
LS1TECH Sponsor
DrTurbo's Avatar
Did Jose end up getting you taken care of on your turbo?
Old 06-15-2007, 12:48 PM
52172's Avatar
He sure did we and going to hand deliver the turbo to them today. That will save me about two weeks shipping time. You guys ROCK!
Old 06-15-2007, 01:48 PM
LS1TECH Sponsor
DrTurbo's Avatar
Well glad to hear that. Jose called it in to let them know it was coming hand delivered....so you should be good to go. Good luck...
Old 06-15-2007, 07:25 PM
52172's Avatar
I will update this post and my Hi-Flo post when we get the turbo back. By any chance were you the one I spoke with on the phone the night before Jose called Turbonetics?
Old 06-16-2007, 09:31 AM
52172's Avatar
We ended up trying a .080 restrictor and then a .050 and the smoking did not get any better. It smokes like a James bond smoke screen car and seems to be getting worse. Turbo is not off car and was hand delivered to turbonetics. Hopefully they will get it back to us quick.
Old 06-16-2007, 09:48 AM
  #32
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
No you spoke with Jason, he was at the shop after hours.
Old 06-16-2007, 09:49 AM
  #33
LS1TECH Sponsor
Let me know if their is a hold up. I will call T-netics and get it moving.
Jose
Old 06-16-2007, 10:07 AM
  #34
52172's Avatar
Thanks Jose! I will do that if there is one for sure. Car will be completely finished after we fix this oiling issue. I'm ready to pick her up from the shop as soon as they get the turbo back. The cool thing about it Rob Barth the shop owner that has my car knows Brian and a lot of the guys over @ turbonetics. Hopefully there are no holdups.
Quick Reply: turbonetics warranty
