Twin GT35r's or PT67's for a 408
Would either of these be a better choice over each other for use on a 408? I can't make up my mind on what I want. Here's what I'm hoping for....A street/strip car with big power potential, solid 9 second potential, stock pcm. Am I just dreaming??? Right now I'm thinking the speed inc kit may be my best choice.
Look up "inspector12" 's post, he uses pt67's on a 402 ls2 and made 840hp on ~15lbs on pump gas on the first pull and wont release anymore numbers. He says they spool by 3000-3500rpms though...
I'd definitely go with 67's if i had the cubes and if I still had a 347 I'd go with gt35r's.
LS1Tech Sponsor
http://www.youtube.com/watch?v=xG0GXbL-GDA
330cid ford racing motor twin gt35r turbos tial wastgates and bov 1400+bhp
The 67's will make more power on pump gas and be better suited to the larger engine....
I have the LQ4 block at 408 CI. I run through a TH400 and made 882 RWHP.
I have a pair of T-67's
Twin Turbo: Part No=PT-67 Max. Rated HP=780
Compressor Wheel Dia.=66.548mm, 84.074mm
Compressor Wheel Trim=63
Compressor A/R Ratio=?
Bearing System=360 Race
Turbine Wheel Dia.=81.28mm
Turbine Wheel Trim=85
Turbine A/R Ratio=.85
I've run out of fuel so I'm stuck here at 18.5 PSI but I'm sure it's got more in it.
If you want more HP though I would go with these
Max. Rated HP=1100
Part No=GT42R
Compressor Wheel Dia.=94mm, 102mm
Compressor Wheel Trim=53, 56
Compressor A/R Ratio=0.60
Bearing System=Ball Bearing
Turbine Wheel Dia.=82mm
Turbine Wheel Trim=84
Turbine A/R Ratio=1.15
The compressor section is pretty big so you'll have to make some room for sure for the 42's.
Max. Rated HP=1100
Part No=GT42R
Max. Rated HP=1100
Part No=GT42R
Max. Rated HP=1100
Part No=GT42R
LS1Tech Sponsor
they are at 1181rwhp on race gas......and there swapping out the turbos for GT4067's
um the man who tunes my car tunes the ttgt and it make just over 1400 on race gas, now my tuners ttgt make 1086 on race gas and they both currently run gt35rs but the one in the video will be changing to gt47-76s in the near future with spray i know the number ive seen it on the dyno
My T-67's are fine for me. My car has plenty of power for what I want in my car.
All depends of what you want. They're are good choice for your motor size as I can show you the results on mine.
How much HP are you ultimately looking for?
Originally Posted by DrTurbo
If your going with a pair of twin GT42-70's then I would go with a pair of ST70's. They will make more power then the GT42's by far. The dual BB will do very little at this point with a big twin setup.
Why do the ST70's claim 1000 HP rating while the GT42 claims 1100? Someone's full of crap on their ratings. Or am I missing something? I mean you stated that the ST series will make more HP by far so Garret must be full of crap. Or are you talking about something other than full out? Please splain yourself....
Depends on what your comparing it to. The GT4294 or otherwise known as the GT42-70 is rated in the link below by GT themselves at 850hp
http://www.turbobygarrett.com/turbob...4_731376_1.htm
The GT4202 or otherwise known as the GT42-74 is rated below as well at 1000hp.
http://www.turbobygarrett.com/turbob...2_731376_2.htm
Also the ETT 70 wheel alone flows 94.XX lbs/min.
How is the intercooler setup? Are you merging into both turbos into one outlet or one on each side and the outlet on top.
Very nice work...
6 Second Club Moderator
Originally Posted by chuntington101
either will get you to 1000bhp. if you want fast spool then you can get the PT67 with BB cores. some of the import guys are starting to use the PT67s now.
thanks Chris.
thanks Chris.
Don't worry about spool with a 408, go big on the exhaust side.
