Best turbo to match 950rwhp with fastest spool on 408...
Originally Posted by 2000 Tran Zam
Hmmmm, so with lets say afr225's (or if i can get my hand ported 205s fixed), a 236/230 cam and 6 speed I should definately see over 750rwhp with a 6 speed... at around 10 lbs or so..
Interesting...
PSJ, lets talk
Interesting...
PSJ, lets talk
I just talked to the speed shop and I guess its bored 30 over now, and needs another 30, so it looks like it'll be aroudn a 414 when its done. The heads seemed to have melted part of the alimunum in the intake part so theyre gonna do something technical(Iforgot what its called lol) and reseat everything to get it to fit and save the heads.
The pistons apparently have like less then 3/1000's clearence (super tight and built like an NA motor as I was told) but the rods were pretty loose...
I'll prob speak to them next week and see what the machine shop says.
Anyone have good experieinces with JE pistons?
I guess theres a 5 week back order for diamond so I might stick with JE.
Shorty Director
Originally Posted by smokinHawk
you have the 6.0 iron block right? i didnt know you could bore it out to a 414
what is your bore size know? and what will you go to, you might check on that cause you might not be able to bore it out that far.
this is the basic info I got from Allan :
Diamond custom pistons.. with Hellfire rings,Manley billet rods 6.125",Callies crank 4.00",king rod bearings and Federal Mogual main bearings.
Piston specs:
*4.030" bore
*1.123" compression height
*-33cc dish
*.200" intake pocket
*.180" exhaust pocket
*1.5mm,1.5mm,3.0mm rings
*.927" x 2.950" H13 wrist pins
*416g weight
Originally Posted by CHRISPY
sonic check the block first...I am surprised you'd need to go 30 over again and not a light hone...
#32
Originally Posted by VINCE
I am with the others on that much of a bore. I would get a new block and start from scratch. You are only talking $500 max for the new block.
The problem is machine work will have to be started all over again which will make my rebuild much more expensive though wont it, since they have to cnc all from the beginning... id rather try to save the block if possible if thats the case.
#33
Originally Posted by B18CYA
Do you think there would be any back pressure problems with a gt42 housing/S80 or S85 and a 408 with heads?
I've got a S80 and on the fence as far as 370 or 408.
#34
Shorty Director
ya Im gonna see what exactly is done damage wise and will see if we need a new block or not.
#35
LS1Tech Sponsor
#36
Originally Posted by Slowhawk
You should tell this new machine shop to build it just like before because that motor was strong as hell and lasted alot longer than anybody would of expected I can bring up a ton of old posts with overheating,missing plugs,racing while overheating and the car just running too lean. That engine lasted through alot of unnecessary abuse
never had missing plugs, just the tops of them :p hahah.
I was at the chevy dealership this weekend looking at the new c6z's...
88k... **** that! lol.
But, my dad really wants me to fix the car and sell it and get a c6z instead. Then a cam, headers, intake, exhuast, tune and 150 shot and Ill be right back where Im at now
What do you think of the idea?
#40
Sounds like a plan, I'll give you $900 for the used turbo.
My dad is helping me finance most everything. He just is tired of **** breaking and having to spend more money so he wants something that will be covered by factory warranty.
Looks like I'll be holding on to the car for a bit then since Im getting offers for 5k
