Auto Meter gauge install.
Old May 5, 2003 | 06:18 PM
Blown Hawk's Avatar
Default Auto Meter gauge install.
How have you guys run your cables to the engine bay? Not sure where to punch through the fire wall? How or where are you guys punching through?
Thanks for the info guys.
Mike
Old May 5, 2003 | 06:35 PM
LS1Bird's Avatar
Default Re: Auto Meter gauge install.
I just drilled a hole and put mine through. I used a grommet, and brought it all out low where the power brake booster blocks the view. It came out good...
Mike M
Old May 5, 2003 | 07:21 PM
Sears's Avatar
!Dial-up Director
I drilled a hole right under and to the right ( from the inside ) of the clutch master cylinder. You have to cut away a piece of the rubber insulation on the firewall to install a gromet. I can take a pic if it would help.
There is an existing hole behind the PCM also.
Justin
Old May 5, 2003 | 07:55 PM
red ws6 99's Avatar
I ran mine through the factory 1.5" grommet on the passenger side. Its wear the all the wiring from the engine bay goes into the car. If you pull the PCM out it is under there. No cutting, necessary and it will look factory.
Gary
Old May 6, 2003 | 08:08 AM
LS1Bird's Avatar
My nitrous stuff was already taking up that "under the PCM" space, that's why I had to drill a new one. That is a great spot to use, but it will make you add a few feet to your gauge wiring/tubing lengths.
Mike M
