What boost to run?
Old Jun 18, 2007 | 03:50 AM
Websy21's Avatar
Default What boost to run?
Just picked up a 2001 WS6 T/A with the mods listed as follows-
K&N High Induction System, SLP 90mm MAF, SLP Bellows, MTI 75mm Throttle Body (ported & polished, fuel heater bypassed), SLP Headers Long Tube, SLP Exhaust Y-Pipe,Trans-Go Shift Kit (4L60E), Borla Exhaust System, Power Exhaust Cutout, BK Performance Transmission Cooler, SLP Springs/retainers/guides, Motive 3.42 gears,American Racing 17" Torque Thrust D Rims (9.5" front, 11" Rear), Mickey Thompson ET Street Drags 315/35/17, slotted & cross-drilled rotors, Hawk Brake Pads, Random Technologies Torque Arm, SLP Trailing Arms/pan hard rod/sub-frame connectors/strut tower/manual fan switch/Draw-Tight Hitch Assembly, MSD Spark Plug Wires, NGK Spark plugs, Vigilante 3200 Stall Torque Converter, SLP Line Lock, MTI High Wall Tension Pulley, 7.5in TA Stud Girdle, Optima Heavy-Duty Battery, ECU custom programmed by MTI to Match Aftermarket Parts
My plans are to put a ATI Procharger on it and eventually a moser 12 bolt. I want to put on the LSX Fast intake but was wondering if its really worth the money and if I should opt for the 78mm instead of the 90/90 setup being that I already have a aftermarket t/b on it? ($$$) Also I keep hearing that the stock internals will take 8psi no problem with the D-1SC. I was gonna get the P-1SC and put on 5psi, maybe 7psi max being that I want a reliable cruiser and not trying to break any records or my car for that matter. If the engine go's in the future though it would be nice to have the D-1SC on it to build a serious boosted motor??? I thank all the gurus in advance!
Old Jun 18, 2007 | 04:35 AM
EPP's Avatar
EPP
Go with the D-1SC, and 8 psi of boost. That is how we set them up, and with a good tune you won't have any problems. I'd install an LS6 intake instead. This 740 rwhp C5 has the LS6 intake, stock maf and stock throttle body.
http://www.exoticperformanceplus.com...Car.php?car=40
Here is our price for the D-1SC kit, and everything that is required to make it work.
http://www.exoticperformanceplus.com....html?item=798 Bob
Old Jun 18, 2007 | 05:28 PM
vaticano's Avatar
i agree i bought the EPP D1SC and put it on my o2 ws6 with heads and cam with 11.4:1 compression on pump gas 91 octane here in denver and have had no problems at all and i actually see 9.5 pounds at 6200 rpm go for it
Old Jun 19, 2007 | 10:02 AM
AFASTYZFR1's Avatar
D-1sc at 8lbs...... .......otherwise you will want more later
Old Jun 20, 2007 | 07:25 AM
Websy21's Avatar
Ya thats waht I was thinking too, 8psi D-1SC, but as for the intake I thought the Fast was suppose to be an improvement over the LS6 intake?
