Motor went south - Rebuild in Progress
Old May 6, 2003 | 11:12 AM
Crunch's Avatar
Default Motor went south - Rebuild in Progress
Didn't think it would happen this soon (4 weeks?)
Perhaps the fuel issue did more damage than I thought.
You be the judge.
http://www.fbodycentral.com/phpBB2/viewtopic.php?t=9394
Old May 6, 2003 | 11:57 AM
Phate's Avatar
Default Re: Motor went south - Rebuild in Progress
Sorry to hear about that.
Sounds like the problem was all tuning related.
I have seen several cars on the dyno (and my own car with the in car wideband) that were dangerously lean on a 2-step before adjustments were made. A lot of people forget to verify it when tuning.
Keep in mind that even the strongest motor won't last under extreme detonation...nail the tuning and then work from there.
Scott
Old May 6, 2003 | 12:18 PM
Crunch's Avatar
Thanks for the tip. This time I'll make sure to monitor everything while the two step is engaged.
Old May 6, 2003 | 12:22 PM
y2khawk's Avatar
You will always show lean while on an ignition cut 2-step. Since your sending alot of unburnt air out the exhaust, you can't rely on O2 readings (narrow band or wide band)
And Scott's right, if your tuning isn't correct your asking for a rebuild. It's very easy to break the strongest parts with the wrong tune.
Old May 6, 2003 | 01:23 PM
Phate's Avatar
Matt,
That is pretty interesting...I always though it was a result of the combination of boost and lack of fuel in the PE v. RPM table at lower RPM.
So it is not as dangerous as it looks...cool!
