S88 on a 408 with stock pcm possible??
Old Jun 19, 2007 | 08:06 PM
theblur98ss's Avatar
Default S88 on a 408 with stock pcm possible??
I'm considering doing an S88 on my 408 over the winter. If I go this route I won't be able to do BS3 this season. Would I be able to run this combo at all on the stock computer? Are there any other options? Maft pro??? thanks for any input.
Old Jun 19, 2007 | 08:41 PM
cablebandit's Avatar
basically what i am running with efilive...no maf..OLSD...i love it
Old Jun 19, 2007 | 09:35 PM
02SSLE's Avatar
I will be running a Twin Maf setup soon. I will be trying it out for a well know tuner that he is developing. on factory PCM with HP tunners
Old Jun 19, 2007 | 10:08 PM
Slowhawk's Avatar
LS1Tech Sponsor
No need for a MAF. 2 bar or 3 bar SD works perfect and easy to tune.
If you have a 98 it's harder due to weak 98 computer but it can be done.Just did one 2 days ago.
Old Jun 20, 2007 | 09:49 AM
Boostaholic's Avatar
x2, like my speed density setup
Old Jun 20, 2007 | 10:59 AM
DrTurbo's Avatar
LS1TECH Sponsor
S88 has been ran on 2 LS1's that I know of with stock PCM's and SD tune. One is above in Kyles car.
Old Jun 21, 2007 | 02:50 AM
lbz34's Avatar
408 PT88 96lb inj and stock ECU here. OLSD 3 bar.
Old Jun 21, 2007 | 06:14 AM
NA$TY-TA's Avatar
You are going to have to run an injector driver box to run 96#ers with the stock PCM to support the power..... I made over 1Krwhp with 38 less cubes with the S88.....
If your really gunna push it you might have to go bigger then that...... last time out i was out if injector... 87%...
Kyle
Old Jun 21, 2007 | 07:52 AM
y2khawk's Avatar
Kyle
that's not close to being out
Old Jun 21, 2007 | 08:46 AM
MIGHTYMOUSE's Avatar
what does it take to go from stock 98 pcm to 3 bar big injectors etc like what the guy needs
tuning platform - efi live or hpt? $
injector conroller - brands and $
3 bar convsersion goodies ? $
wideband and controller / converter $
98 to 99+ pcm conversion $
i see aftermarket EFI boxes go through the f/s section for 1500+/-
Old Jun 21, 2007 | 08:54 AM
oufan2929's Avatar
This is good news to hear!!! I'm fixing to be doing the same thing...stock pcm and 3bar sd tune w/an S88!
Old Jun 21, 2007 | 05:45 PM
I should add that I already have HPT and an LM1 wideband if that helps or hurts me any.
Old Jun 21, 2007 | 05:54 PM
NA$TY-TA's Avatar
Yeah was talking with Derty today and he said the same thing.....
Old Jun 21, 2007 | 05:55 PM
NA$TY-TA's Avatar
The only thing is he is a 98 pcm and no one has a 3 bar set-up for it... the damn bastard child...
2 bar yes.......
Like MM said... add it all up for a 98 car and your close to a stand alone set-up..... Im looking at one..... maybe...
Kyle
Old Jun 21, 2007 | 09:58 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
2 bar yes.......
Kyle
Or you could convert to a 99+ system for the cost of the PCM, engine harness, and connectors. That's what I plan on doing shortly.
Old Jun 21, 2007 | 11:54 PM
EATON22's Avatar
As I here eveerybody talking about a 3 bar I am wondering if you are going to be running very little on the street and mostly on the strip. That means Race Gas or ment injection for the street. It is not the boost alone that makes horsepower; it is a combination of boost and CFM.
I have seen cars with higher boost, but restricted exhaust or intake systems on a Turbo Car make much less horsepower than a well designed Turbo system with lower boost. It all works together. What you really want to know is how much CFM can the Turbo push through the Turbo system.
Old Jun 22, 2007 | 06:39 AM
2 bar yes.......
Kyle
thats what i was thinking.. well went ahead and added that to the expense list..
Old Jun 22, 2007 | 09:21 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I thought HPT had come out with 3bar for 98's.
Old Jun 22, 2007 | 10:16 AM
Mr.MartyStone's Avatar
I don't think there was ever a resolution to this question. I had asked the guys at HPT about the 3 bar setup and they said they had no intentions of producing that product, but they also said the same thing 3 years ago when I asked about 2 bar SD setup availability. Maybe they will chime in on this thread.
Marty
Old Jun 22, 2007 | 10:20 AM
Mekkadon's Avatar
nope
